Originally Posted by
grumpygeek
I used the 4 pin aviation connectors from ebay on my last build and I think they are great, they screw together so they won't accidentally get disconnected and short of getting them wet I think they should be no issue with contamination. Being able to easily swap to different controllers to see if it is a wiring/motor issue or a controller issue is nice. There have been times when I have moved my machines around and having everything hard wired was a bit of a pain, if you control box is part of you machine and you just need to disconnect a usb or serial cable I guess this is less an issue. I have 3 different controllers, I am planning on wiring the other 2 in the same configuration so I can swap them out if needed.
