586,537 active members*
2,798 visitors online*
    Jun 2006
    How to slot a rectangular slot with convex bottom ?
    Can anyone suggest a program that I can use to get a slot cut on my 3axis mill, using Mach3.
    I need a rectangular slot into a half round metal sphere, where the bottom of the slot is as shown in the picture is the Z depth.
    I have searched high and low but nothing seems to answer this question, so perhaps someone here can help out.
    Regards, Brian
    Apr 2004
    475
    Re: How to slot a rectangular slot with convex bottom ?
    Well, the cheap way would be to program the slot in xy moves, program the curve of the slot in xy moves, then change some letters around and you'll have the z code, with a g17(?) In front instead of a g2/g3. My control doesn't do those g codes, so no direct experience. Put the curve code in place of / addition to the slot code and you should be good. Or, get out the graph paper and do by hand.
    Sent from my ASUS_Z00TD using Tapatalk
    Jun 2006
    Thank you very much for the reply. I will look into trying it that way.
    Seems incredible that there is not a program available to do such a simple job.
    Oh well that is the fun of hobby cnc.
    Thanks, Brian
  1. 36 x 60 v slot
    By dsorrells in forum Open Source CNC Machine Designs
    Last Post: 04-22-2015, 02:14 AM
  2. one slot is coded other slot is not there
    By cwaugs in forum Uncategorised CAM Discussion
    Last Post: 05-06-2011, 03:00 AM
  3. Curved bottom slot?
    By DonW in forum BobCad-Cam
    Last Post: 09-18-2008, 08:51 PM
  4. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  5. Replies: 7
    Last Post: 04-12-2007, 03:00 AM
