The sawdust dryer, refers to sawdust drying machine or sawdust rotary dryer, means to continuously feed wet sawdust powder into dry tubes with screw conveyor. Evaporate wet material moisture in the transmission and spread of high-speed hot air flow, getting dry powdered or granular product. Sawdust dryer is mainly composed of air heater, air feeder, air drying tube, cyclone separator, blower and other components.
Drying Tactics:
1. Before the start of sawdust dryer, check the connection of the power and if the rotating cylinder is in the right position. Connect the power supply and open the upper cover and run the rotating cylinder with no load. The rotating direction should in accordance with the direction label. It there is still no hot blast after 5-minute working, stop the machine and check if the air discharge mouth is blocked.
coal slime dryer
2. The cover should be put down when the machine is working. Machine should shut down when install and unload the work pieces. Pay attention that the work pieces should distribute in the cylinder uniformly otherwise the dehydrator will shake violently.
3. To stop the rotating cylinder, first shut down the motor. Then stamp on the brake pedal, but keep in mind that brake cannot be conducted until the motor is shut down.
Sawdust dryer is mainly composed of air heater, feeder machine, pneumatic drying pipe, cyclone separator and draught fan. The working process of this machine is that the spiral conveyor is used to continuously send the powdery wet sawdust into the drying pipe, and in the conveyance and dispersion of high-speed hot air, the water containing in the wet materials will evaporate, thus getting powdery or granular dry products.
Fote Heavy Machinery: http://www.ft-dryer.com/products/Industrial-dryer.html
Fote Official Website: [email protected]
