Mixed laser cutter for thin metal and thick non-metal materials
Mixed laser cutter is mainly designed for cutting thick non-metal material, such as Acrylic, MDF, Die Board, and 2mm Stainless Steel. The feature of this laser cutter is perfect cutting effect and high cutting speed.
Mixed laser cutter for thin metal and thick non-metal materials is not the ordinary CO2 laser machine, it can cut and engrave not only all nonmetal materials, but also metals.All the machine parts and controller etc use original parts, long time use without deformation.
Features of mixed laser cutter :
1.Laser head with automatic follow-up control system:It can detact the surface of the metal materials and adjust the laser head automatically.If the thin metal materials is not flat, the laser head can move with it up and down.
2.High speed DSP offline control system with colorful TFT screen displaying and USB interface.2MHZ data transfer and designing display on screen.Dynamic display the working process during machine cutting work.Can change the parameter on TFT panel.
3.USA imported focus lens.
4. Industry heavy duty machine body to ensure machine stable and high precision
5.Whole set imported guide rails and ball screw from Taiwan.Leadshine stepper motor with driver more powerful and accurate.Japan Yaskawa servo motor for choose.
Application of mixed laser cutter :
1. Advertising industry: Stainless steel. Acrylic plate. color board and other advertising materials engraving and cutting;
2. Leather garment processing industry: Leather, fabric carve or hollow out patterns;
3. Arts and crafts industry: Paper cutting, wood, bamboo, leather, shell, ivory and other materials engraving and cutting;
4. Modeling industry: Aviation and maritime models, wooden toys engraving or cutting etc;
5. Packaging industry: Rubber printing plate engraving and cutting, bilayer plate, dye board cutting etc.
6. Decoration industries: Electrical and electronic industry materials' engraving cutting.
STYLECNC is a guaranteed manufacturer for CNC Router, Laser Cutter, Laser Marker, Laser Engraver, Wood Lathe and Plasma Cutter. Official website: https://www.stylecnc.com/
