586,082 active members*
3,831 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Relay for spindle on/off
Results 1 to 15 of 15
    430
    I want to hook up a relay to control my spindle. Just on/off.
    I am assuming a 5V relay, what kind of amperage rating do I need for the contacts? I use a dremel tool for the spindle, but I dont know how much current it draws. The biggest I can find is 3A, all the rest are 500mA or less.
    Has anyone done this? Any suggestions on how to hook it up?
    co
    779
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    430
    Thanks for that,
    co
    24221
    Keep in mind that these are printed circuit type and the contacts are usually rated for resistive load, if you intend switching even a dremel, especially switching at full rpm setting, these contacts may not last long, I would go with something a bit heavier rating and terminal type rather than PC type. If you want to get really fancy pick up a surplus solid state type with 5v input and 110vac load. Probabally last you for ever.
    Al
    BTW if you do use a coil type relay, don't forget the reverse emf diode across the coil. (typically a 1N4007).
    430
    Thank you.
    I have little knowlege about this type of thing and I would like it to work right from the start with no blowing things or me up.
    That link showed none in stock and none on order. I guess a trip to an electrical warehouse might get me what am looking for.
    co
    Feb 2004
    93
    I use Crydom solid-state relay.Take a look at www.stepperworld.com clik on the link extras to see what is it.
    It`s opto-isolated so no risk of blow your board.
    Alex
    Jan 2004
    digi-key part #Z193-nd 12volt dc switch contact 110v 15a Relay
    430
    Mintz, you got me all excited. Unfortunately that is a 12 volt coil, I need 5V coil.
    I like the shaft couplers at stepperworld, anyone have experience with them? Are they sloppy or tight?
    co
    24221
    CO, Its looks like you may have to go with a printed circuit type relay after all, I could not find any 5v with terminal connection.
    Omron has a PC type G2R1-DC5 10amp contact, available from Electrosonic for Can$5.10, Electrosonic has an office in montreal.
    Al
    430
    Thanks for that.
    co
    Oct 2003
    175
    check with any electronic suppliers around your town i used an NTE RS3-1010-51R SSr 10amp rating origanally started with a dremal but bumped up to a craftsman rotozip copy has like a 5amp rating on the motor used pin 1 for the control with turbocnc you might look on xylos fourm too i think theres some info on it
    Jan 2004
    24
    stepperworld.com,extras page has a relay for $22 is what I use. 5 volt logic will drive it.
    430
    Thanks everyone. I have looked a little for info on how to hook it up to the xylotex board, but honestly havent had much time to do it. If I cant source the one mentioned in Montreal I will get the one from stepperworld along with a few of those shaft couplers, anyone used them?
    Was considering just hooking up a switch to the relay on the Z and setting it so when I get to a certain height the motor shuts off or goes on. That way I could have a standard Z height at the end of the run that would shut off the spindle. Much slicker to use the m3 and m5 though.
    co
    430
    Well I went to a huge electronics warehouse today and picked up a relay. 5V coil and 125VAC 20A relay.
    Question is, how do I hook it up?
    There are 6 pins on the bottom, 4 on one end and two on the other. I am guessing that the two are the 5V input and the 4 are for the load.
    Anyone give me a bit of guidance on this?
    thanks
    co
    234
    yukonho
    If you are using Turbocnc, try looking at this site http://www.teilhardo.com/Spindle%20Control.html
    I just completed the installation and it works great.
    Marv
  1. Relay question
    By shortbus in forum CNC Machine Related Electronics
    Last Post: 04-26-2005, 10:14 AM
  2. How to set a relay for a spindle motor ON/OFF control
    By TTaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-09-2005, 01:26 PM
  3. E-Stop Hard Wire and to Software?
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 10-30-2004, 05:22 AM
  4. Mach2 & Rutex relay board.
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 08-22-2004, 07:50 PM
  5. How to control a relay with a PC
    By NeoMoses in forum CNC Machine Related Electronics
    Last Post: 08-06-2003, 11:55 PM
