First of all, Thank you for looking.
I want to use an aquarium style pump for my air assist and would like to know how many lph or gph is enough.
I know I can use a compressor set at approx. 5-6 psi but that's pressure and aqua pumps are rated by volume.
I am on a very tight budget for this and simply put, don't want to spend $150 on a pump if the $35 one is sufficient.
I have found posts claiming as little as 9 lph and as much as 3200 lph is required. A bit too big of a gap for me to have any clue as to where to begin.
It's the K40 laser and I will mainly be working with wood and acrylic.
Thank you for any insight you may be able to provide me on this, Jeff .
