586,103 active members*
3,484 visitors online*
    Nov 2010
    13
    Mach3 UC400eth and joypad
    I have an issue with the joypad ( joypad plugin version 2.0 ) control.
    The problem is that the machine respond to the proportional control of the joypad command, but once started moving it does't stop when you stop action on the joypad, it only change direction if you move the lever in the opposite direction.
    Any idea ?
    thanks
    Aug 2007
    18
    Re: Mach3 UC400eth and joypad
    Quote Originally Posted by silverdog View Post
    Any idea ?
    thanks
    Hi Sergio,
    I assume you are talking about the included xbox control plugin that comes with UCCNC (ref picture attached)?
    Every button press calls a 'button down' code, and on button release, calls a 'button up' code. So for jogging in X+ direction for instance, you would call button code 147 on the 'button down' to start moving, and call code 229 on 'button up' to stop moving in x+. You have to do this for every directional button with the proper codes. The stock plugin doesn't come fully setup for all codes.
    Regards,
    Eric
    Nov 2010
    13
    Thank you for the hint Eric,
    I will give a look at the plugin configuration.
  1. Using USB JoyPad or game device with Mach3?
    By area51b in forum Mach Software (ArtSoft software)
    Last Post: 03-28-2024, 05:03 AM
  2. UC400ETH and Mach3
    By vmax549 in forum UCCNC Control Software
    Last Post: 04-08-2016, 05:24 AM
  3. Joypad
    By fraallan in forum Jewelry Design Software
    Last Post: 05-14-2012, 10:40 AM
  4. Joypad problems. HELP
    By flash319 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-09-2010, 05:28 PM
  5. Latest BDI with Joypad?
    By benedict in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2007, 06:59 PM
