586,121 active members*
3,758 visitors online*
    Jul 2014
    EZ Router Problems
    Is there anyone on here htat has an EZ Router Green Machine with ATC that is having issues with theirs. I just purchased a 4 X 8 table with Auto Tool Changer. I have been getting "Ethernet SmoothStepper" error messages and the machine stops in the middle of the cut. Sometimes it happens within 5 minutes of startup and sometimes it take 3 hours. I have had a technician out to the house twice and still not fixed. They are coming back to swap out the control PC to see if that fixes it. If anyone else has had this issue what did they do to fix it? Also the clearance between the X axis drive motor transmission and the tool holders is non existent and I keep knocking tool holder out of the clips. Anyone else experience this? Just tired of not being able to use my machine.
    Wes
    Feb 2022
    7
    Re: EZ Router Problems
    good website and I had a router problem
    It Is Modified Bitumen Is Comprised of Bitumen and Polymers as Well as Fiberglass in a Thin Layer. It Helps Simplify the Roofing Process While Solving Some of the Issues Associated That Come with Bur.
  1. Problems about the CNC Router
    By Cassiel-Roctech in forum Roctech CNC Routers
    Last Post: 11-22-2014, 04:27 AM
  2. Emach router table problems
    By Navara1 in forum Commercial CNC Wood Routers
    Last Post: 05-20-2013, 08:53 PM
  3. Router Problems
    By sodfarmer in forum DIY CNC Router Table Machines
    Last Post: 05-17-2010, 12:32 AM
  4. Problems with my CNC router
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 10-08-2008, 09:52 PM
