586,058 active members*
4,449 visitors online*
Page 3 of 3 123
Results 41 to 46 of 46
  1. #41
    Aug 2007
    92
    Re: Extron E320 CNC mill communications.
    I was told the same about the control being close to a Fanuc but it doesn't seem to share much, definitely not post processors. I've got a post I did for F360 based on an Atrump one that works, it still needs a bit of tweaking but I don't use it that much, only when I need to do 3D stuff. You're welcome to a copy if you want it.
    I've got a really good post for Sheetcam. I use it a lot for anything 2.5D as it's really quick to spit out code from a dxf and takes about an hour to learn.
  2. #42
    Nov 2021
    15
    so... got machine few weeks back for a shop up at the GC that was upgrading was being used all good they had the titan dnc on the side had used it for big files but mosty program on the control. Got the machine here and hooked up all good.
    I draw in fusion then post ( unsure if i have exact correct post ) i then take over stick the usb in the dnc click on file and make it ready to send on the dnc. at this stage ive hit rs232 on controller and hit read and nothing happens on controller or the dnc. tried bunch of times so looked at the settings they were different then what is in the MIRL book so i changes them over still nothing looked at settings in DNC changed them to line up best i can as MIRL and nothing.
    toady i found a cable int the cabinet went and got a rs232 to usb adaptor from jaycar went straight to rs232 to pc downloaded prodnc ( got setting as close as i thought ) tried again on control rs232 button then read and nothing.
    if someone want to weigh in they can even give me a call on 0427498047 I really dont know what way to head with this.
  3. #43
    Nov 2021
    15
    hey mate would love anything i can get settings posts etc im really at the end of my rope with it with burning heaps of time and achiving nothing
    if you want to email or send me stuff be great [email protected] or 0427498047 iv based in dubbo
    thanks bud
  4. #44
    Nov 2021
    15
    Quote Originally Posted by proengines View Post
    thanks bud
  5. #45
    Aug 2007
    92
    I just e-mailed you the F360 post and some other details about the way I've got mine networked to the PC. Give me a call tomorrow and I can give you some more specifics.
  6. #46
    Good Morning,
    Checking if this thread is still active, Have an Extron E320 with Mirl2000 controller, we had 4th Axis Working but after turning it off in the controller and then now turning it on it doesn't seem to be on the screen, we have multiple replacement drives and a few spares after having a few faults, we keep chasing this thing down the rabbit hole and now I believe we're in too deep to stop.
    Any info suggestions, manuals (or some godly advice on parameters) would be welcomed and appreciated
    email address is [email protected] or 0455471411 if you want to have a chat.
    Nick
Page 3 of 3 123
  1. HELP, Wiring diagram for Extron/ Hafco BM 90VCNC mill needed.
    By oliomio in forum Knee Vertical Mills
    Last Post: 02-11-2021, 05:56 AM
  2. Fagor 805M parameters lost extron BM90
    By david2259 in forum Fagor Automation
    Last Post: 09-14-2011, 12:31 AM
  3. Communications
    By JOHN PARSONS in forum Want To Buy...Need help!
    Last Post: 07-07-2010, 10:43 PM
  4. communications help
    By goaler in forum Okuma
    Last Post: 01-30-2010, 05:07 PM
  5. Extron Milling Machine Upgrade
    By ferman in forum Controller & Computer Solutions
    Last Post: 10-12-2009, 01:51 AM
