Re: Best Machine for 6061 Aluminum plate up to 1/2"
I have milled some rather large 1/2 aluminum plate with the KRMx02 CNC. There are many considerations though. While a machine can be built that has the rigidity to cut a piece of aluminum plate that thick and at the size you want ( I have done it on the KRMx02) there are other considerations.
Clamping
You must have the ability to firmly clamp the plate to the table. This can mean more than just attaching it at the edges.
Chip removal
This is very critical. You will certainly need some addons to accomplish this. Compressed Air/ High static pressure vacuum system. You will also need some sort of lubrication. For aluminum a good misting system can do wonders. It will not be a fast process.
Time
Look for this job taking between 1-2 hours depending on settings and finish required on a CNC router with a bit designed for cutting aluminum on a CNC router.
Cost
The KRMx02 build size that would accomplish this would cost you at least $5000.
Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
