586,350 active members*
3,265 visitors online*
    Apr 2016
    5
    CNC CINCOM B12-Calibration
    Hello.
    I need help to calibrate the back spindle with main spindle, because maintenance take off the back spindle to repair and put again but they didnt the correct calibration.
    Thank you for your help.
    Jan 2010
    134
    Re: CNC CINCOM B12-Calibration
    ENG-CJPC, contact Citizen, they should have a procedure for this. It should be relatively easy.
    1. Put dial indicator in sub
    2. Jog to guide bushing (without a guide bushing)
    3. Indicate along the angle of the guide bush sleeve
    4. Loosen bolts that hold the sub-spindle
    5. With rubber mallet, tap the plate that holds the sub-spindle until your dial indicator is good.
    6. Tighten bolts
    This gets the horizontal position correct and generally acceptable for most parts and applications.
    If the sub-spindle is out along the vertical position, I believe you may need to use shims (under the sub-spindle plate) to get it correct.
    However, call Citizen, they should have a procedure for this.
  1. cincom citizen L20/3M7
    By mustijo in forum CITIZEN Machines
    Last Post: 02-01-2019, 11:20 PM
  2. Citizen Cincom L16
    By steelway in forum CITIZEN Machines
    Last Post: 02-01-2019, 11:08 PM
  3. 351 SPC Alarm Cincom B12
    By ENG-CJPC in forum Uncategorised MetalWorking Machines
    Last Post: 04-13-2016, 05:46 PM
  4. L20/L16,3M7,CINCOM
    By sepganesh in forum CNC Swiss Screw Machines
    Last Post: 02-26-2012, 06:27 PM
