Hi
I'm looking to confirm if the power supply I choose will be ok or be too narrow to survive a 4th axis build.
I intend to build a rack and pignon with 2x 500oz Nema23 on Y and 1x on the X. All those running direct drive with 17teeth pinon, no gear reduction.
Nema spec as : 570oz 3v 5a 2.5mH calculated voltage 15x= 45 20x= 60.
I will use a 48V switchingpower supply. I see I need to plan for a bit of overhead to not fried it. Is using a value of 0.7 for the efficacy will be ok or too high for the nema amp?
As 5amp giving me = 3.5amp * 3 motor running at same time = 10.5amp
The Z should be active just alone, but on the 4th axis, the motor will spin too, at same time of 3 other.I will end up with a 14amp then.
Is a 800w 17amp switching pwr will be ok, for a 4 axis or better to go over a 20amp ?
Without going to the linear power supply route..
Thanks very appreciated, i'm quite stall over the amp rating for quite a while.
