586,060 active members*
4,311 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Animatics Series 5000 servo controller info
    Apr 2013
    162
    I spent some time digging in archive.org and found this Series 5000 Servo Control Descriptions Some pinouts and a bit of technical info that may be of use in getting an old ProLight 2000 running with something other than the old DOS software.
    Google animatics legacy series 5000 and you'll turn up some PDFs buried in Untitled Document for old products from the 1990's but without MOOG Animatics giving up the file names, if there are files in there with useful info on the CD5306M (3 axis) and CD5406M (4 axis) nobody will be able to find them.
    Somewhere in someone's old file cabinet and software backups there must be copies of the technical info and software for these things. Around the turn of the century, Animatics dropped their servo controller line to make only smartmotors, and all info on the 5000 series was either deleted from their site or hidden.
    Did any CNC machines other than those from Light Machines use these controllers? If so, perhaps another company has kept the information. A PLM2000 is a very nice mill, pretty much nothing new is made in its class - won't find a new benchtop CNC mill with that has a 100 pound working load limit, not without it being larger, heavier and severely pushing the upper boundaries of "benchtop".
    Other info I've dug up.
    Intelitekdownloads.com
    Intelitek Downloads
    https://drive.google.com/file/d/0Byh...w?pref=2&pli=1 <-Intelitek CNC Resource Center. Some tech info and repair/replacement plus assembly instructions for ProLight mills and lathe.
    https://docs.google.com/file/d/0Byhq...NhVXBnT00/edit
    http://tinyurl.com/lightmachines
    ftp://ftp.robotec.co.il/Techsup/cnc for laptops/
    For spectralight ftp://ftp.robotec.co.il/Techsup/cnc software/
    ftp://ftp.robotec.co.il/Techsup/To Moshe/intelitek_online_resources/ <-content deleted.
    http://www.graco.unb.br/alvares/DOUT...roduction.html <-Purdue University CAD LAB program created a 3D CAD/CAM program to output G-Code specifically for the PLM2000 DOS control program - then the software went buh-bye when the CAD LAB was shut down in the early 2000's. It *was* all available as free downloads from their FTP server but as yet nobody has owned up to still having any copies.
    Apr 2013
    162
    Re: Animatics Series 5000 servo controller info
    Huge thanks to Chuck Searcy at Moog Animatics (he worked at Animatics before the buyout) for digging through some old backups and finding this trove of technical and programming information and software for the Animatics 500 series servo controllers.
    https://jumpshare.com/b/YbrLmD7bz7Dsxfuzf6GQ
    I also uploaded it to Dropbox https://www.dropbox.com/s/8o87wzopl4...D5XX6.zip?dl=0
    Dec 2010
    Quote Originally Posted by Galane View Post
    Thanks for sharing this, very interesting. I routinely look for info on the PLM2000. Mine runs, but eventually something will crap out - Probably the old computer running DOS.
    Apr 2013
    162
    Hopefully someone can use that information to add support to Linux CNC
    Apr 2013
    162
  1. Any info on an old Animatics control box?
    By Galane in forum Servo Motors / Drives
    Last Post: 03-09-2015, 05:06 AM
  2. Servo Drive - MULTICAM 5000 Series.
    By Routerfiend in forum Servo Motors / Drives
    Last Post: 01-22-2014, 09:55 AM
  3. Too many steps on Z-Axis Servo - Animatics Smartmotor
    By MaxH in forum Servo Motors / Drives
    Last Post: 02-22-2013, 11:10 PM
  4. Multicam 3000 Series vs AXYZ 5000 Series
    By adamfilip in forum Commercial CNC Wood Routers
    Last Post: 10-18-2010, 08:54 AM
  5. Help with an animatics c5200 controller
    By sdswp5 in forum Servo Motors / Drives
    Last Post: 06-14-2008, 02:57 AM
