586,036 active members*
3,346 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Vcarve in V26 - arc moves not working?
    Jul 2012
    13
    Is the vcarve routine in V26 not capable of generating arc moves? It has radio buttons for arc moves in the posting menu when setting up the vcarving and a setting for arc slowdown in speeds and feeds, but even having a drawing with nothing but two concentric circles as the geometry generates super tiny line segments. Am I missing something obvious or does this just not work in V26 with Bobart?
    Sep 2012
    1195
    Re: Vcarve in V26 - arc moves not working?
    My initial experimenting seems to show that you don't get arcs in V-carve. That said, is there a quality issue when the parts are done? My experience has been that with modern controllers, its almost no longer an issue worth worrying about. If you have an older controller which runs jerky with segments, then I can see the disappointment. Seems that if the quality of the finished cut is to your satisfaction, that should be what matters most. If not, maybe you can boost the quality by adjusting the tolerances in the settings?
    Jul 2012
    13
    Not really a quality issue on the parts, more an annoyance trying to refine things. I was trying to speed up my feed rate and was more concerned about the inability of the arc slowdown settings not actually doing anything. Honestly, any of the issues I have with needing to slow down on the arcs is probably poor settings in Mach 3 on my part, but was disappointed when I realized that the setting did nothing.
    Apr 2009
    3376
    Turn it up
    Your machine will be the limiting factor on feed
    If it starts beating the piss out of your machine,,then turn it down or buy a better machine
    I agree with mmoe
  1. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  2. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  3. VCarve Placement of working Peice
    By KenR60 in forum Australia, New Zealand Club House
    Last Post: 01-03-2015, 11:17 AM
  4. Replies: 9
    Last Post: 08-06-2014, 10:16 PM
  5. Replies: 1
    Last Post: 11-15-2007, 01:51 PM
