586,103 active members*
3,065 visitors online*
    May 2014
    11
    Question How to have script running in the background?
    I want to have a script constantly running while Mach3 is running, checking certain conditions and acting accordingly. Specifically, I want to halt all motion when the plasma torch is supposed to be on but isn't because the cutter stops when it overheats, has insufficient air pressure, or trips the circuit breaker. If something was constantly checking to make sure the Arc ON signal is active when OUTPUT1 is enabled I'd be golden. I tried having a custom M-code running an endless While loop (While 1>0) and initializing it a startup, but when I go to load G-code file the toolpath progress bar hangs and the toolpath isn't generated. Mach3 doesn't seem to be able to run more than one VB scripts at a time.
    Re: How to have script running in the background?
    Enable the macropump in General Config, and name your macro macropump.m1s
    May 2014
    11
    Thank you again Gerry!
  1. Bobart Background textures
    By tlharris in forum BobCad-Cam
    Last Post: 01-08-2015, 02:28 AM
  2. Background transfer by pmc problem
    By kningzer in forum Fanuc
    Last Post: 09-08-2011, 09:33 PM
  3. Background Color
    By weirdharold in forum UG NX
    Last Post: 11-23-2008, 02:43 PM
  4. Background bitmap?
    By THend in forum Mastercam
    Last Post: 05-31-2008, 10:33 PM
  5. background in artcam
    By menewfy in forum ArtCam Pro
    Last Post: 07-24-2007, 07:35 AM
