Hello
The mill runs fine with its feed and rapid the first time it's ran .Until you use the overide dial . Then rapid and programed feed rates drop right off to say 30 or 40% even after the override is put back to 100%. This then stays at the lower rate every time the cycle is ran . The only way we correct it is reboot the machine. The feed rate in the program doesn't change.
Any ideas please?
