587,011 active members*
3,802 visitors online*
    Apr 2016
    Lasercut problem
    Please make attention to the oblique cut. Vertical and horizontal cross-sections are normal. Angular cross-section like this
    Nov 2012
    492
    Re: Lasercut problem
    whats the problem?? more info what laser what wattage what material what thickness. How do you expect anyonr to help you when you supply no information(chair)
    Apr 2016
    Quote Originally Posted by Bigbird48 View Post
    Leetro mpc6585 double laser machine. 130 wattage.
    Cutting organic glass or wood and any other material direct lines cuts normal, oblique and curved lines cuts zigzag. areas and BOLTERY 😬 we checked everything is normal , there is no change , and during different speeds also it's not give change . Cutting Rectangular is not 90 degrees
  1. Problem with LaserCut 5.3
    By ozkanaybay in forum LaserCut
    Last Post: 04-17-2015, 09:40 PM
  2. Problem with pattern in lasercut 5.3
    By woody75 in forum LaserCut
    Last Post: 03-07-2015, 05:14 PM
  3. Problem with Lasercut?
    By lasernewbie in forum LaserCut
    Last Post: 10-27-2014, 05:37 PM
  4. Is Lasercut casuing this problem
    By BuckeyenNJ in forum LaserCut
    Last Post: 05-17-2013, 11:06 PM
  5. Problem with lasercut 5.3 highspeed cutting
    By zoefie in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2010, 02:35 PM
