586,036 active members*
4,277 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc oi-td boot system backup problem!!!!
Results 1 to 11 of 11
    Aug 2015
    27
    Exclamation fanuc oi-td boot system backup problem!!!!
    Hello cnc masters.Can me help.please.My cnc fanuc oitd model..i dont backup because protected..how to disable protected.Boot system....THanks everybody..
    Apr 2009
    1379
    Re: fanuc oi-td boot system backup problem!!!!
    Normally you can only do a sram backup in the boot menu. System files don't need backup.
    Oct 2014
    137
    Try for entering in boot menu with press together two extreme buttons of the arrows <- ->.
    You can NOT. Even in User Private mode. Fanuc now requires a special card that must be inserted next to the monitor to allow saving of these files. Only Fanuc has these cards. If you were to lose these files Fanuc can restore them for you. The files that will come out Fanuc can not restore for you so you better have those saved too. Don't forget to press page down to get to all the screens.
    Aug 2015
    27
    Quote Originally Posted by agering View Post
    Agerin i can enter boot menu .but i cant backup sram and system file......write protected priblem
    Aug 2015
    27
    Quote Originally Posted by drdos View Post
    fanuc special card?only for fanuc?
    Apr 2009
    1379
    "Fanuc now requires a special card that must be inserted next to the monitor to allow saving of these files. Only Fanuc has these cards." please clarify 'now': as of when? What is so special; about them?
    I have always used sram pcmcia cards in the BOOT mode; the 'i-series' can also use linear flash cards, afaik.
    Feb 2015
    161
    From the picture, it says memory card full. According to your screen, you need at least a 2.6MB memory card to back it up. You cannot split the file onto 2 or more cards/files. Make room on your memory card.
    drdos is correct. DO NOT backup System files. That is FANUC software. On the new controls, saving them will REMOVE them from the control, the only way to load them back in is with a special card that FANUC does not provide customers.
    Aug 2015
    27
    stl my cf card empty but cnc say:memory card full(
    Try Formating the Card in BOOT
    Aug 2015
    27
    formated but dont work
  1. Backup System and Files
    By cncadmin in forum Autodesk
    Last Post: 10-19-2013, 01:30 AM
  2. fanuc system backup
    By dbs-t in forum Fanuc
    Last Post: 08-01-2012, 03:05 PM
  3. problem with the system FANUC M6
    By monika13361 in forum Fanuc
    Last Post: 11-24-2011, 09:43 AM
  4. Replies: 1
    Last Post: 11-22-2007, 02:55 PM
