Hi, I Martin from Argentina.
I have a goldenlaser with two fixed heads, and software is really bad. And without support (chinesse and either local)
Then i purchased a RDC6442s in china, right now i am waiting.
Of course, i installed RDwork V8, and start to play... but apart of ugly operation manual, some labels into the software are at least, confusing...
Then, I open the directory of RDworks and found some .txt like : lang_eng.txt and lang_other.txt
Close rdworks,
Simple open lang_other.txt with notepad, looking for .... "if blowing", found it, and changed it for ... "Air assist"
Repeat
go to "1" and so on...
Then, open wdworks, and change languaje to "Other"
Why Other and no Eng ?
with you "new" languaje you are out of manual operator, or talk to other users, because you dont have anymore the "old" labels...
solution : dont change lang_eng.txt, just change other_lang.txt then, if you need to find some "old" label, change to english, once found, you can change to "other" and operate normally
Other cuestion, if you change a label and the number of characters is too much diferent (more), posibly the text appear over other items... be carefully
And finally, in a upgrades of software i dont know what will be the result... maybe try and start again...
Examples for me :
if blowing = Air assist
Sew compensation = Kerf compensation
if light = Laser On
Martin.-
