586,036 active members*
3,540 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > ETHERNET PROBLEMS ON ARUMATIK CONTOL (MITSUBISHI)
    Apr 2016
    DOES ANYONE KNOW HOW TO GET FILEZILLA TO CONNECT TO ARUMATIC CONTROL??? PLEASE HELP
    Apr 2009
    32
    Re: ETHERNET PROBLEMS ON ARUMATIK CONTOL (MITSUBISHI)
    Quote Originally Posted by edp42 View Post
    I am having the same problem too.
    Apr 2009
    32
    Quote Originally Posted by sunnybank View Post
    Found an alternative solution.
    Since Arumatik control is Windows 8 embedded system we can simply use Windows built in file sharing.
    I plug a USB wifi card in front USB port. Press ALT+F4 to switch to windows desktop. Complete wifi driver installation.
    Connect to you wifi network. Create a folder in D drive.
    I use username "M800", password "CNC" to access shared folder from other computer.
    Not sure if it's default access account or not.
    Hope that helps
  1. MITSUBISHI 700/70 Series ETHERNET PROCEDURES
    By mousongie in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2021, 03:42 PM
  2. Rigid tap retraction in arumatik jr
    By harishmech10 in forum Kitamura
    Last Post: 12-29-2015, 07:01 AM
  3. Problems with Ethernet on Fanuc 18-i MB
    By yoqse in forum Fanuc
    Last Post: 02-10-2015, 11:44 AM
  4. Mitsubishi control multiple problems
    By jdatbmc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-29-2009, 02:38 AM
