586,103 active members*
3,882 visitors online*
    Oct 2008
    2100
    62mm 110V Spindle
    I am looking for a 62mm diameter body 110V 24K rpm spindle as a spare for one of my machines.
    I can find 65mm, but I want a 62mm so all I have to do is swap the spindle when it starts to go bad. It will go bad. I put a lot of hours on it.
    I can only find old no-longer available listings for 62mm/110V spindles. In 62mm the only current ones I am finding are 220V.
    Also, does anybody know of a domestic source (USA) even for the 62mm 220V spindles? I'd swap VFD if I could swap out spindles faster and easier.
    Bob La Londe
    http://www.YumaBassMan.com
    Oct 2008
    2100
    Re: 62mm 110V Spindle
    I never found one. I did find a 62mm spindle that would fit in my application, but it was 220. I didn't want to rewire a bunch of the machine so or tie up another 220 break in my rather small panel, so instead I installed a Hitachi 110V in 220V out VFD. The combination cost me a lot more than I wanted or thought it should have, but I got the machine back in service. Its happily turning large pieces of aluminum into small pieces of aluminum right now.
    Bob La Londe
  1. 110v 1.5kw VFD & Spindle Producing a Shock
    By Parke in forum Spindles / VFD
    Last Post: 04-19-2016, 05:20 PM
  2. 0.4 kW air cooled spindle with 110v Delta VFD
    By DonFrambach in forum Spindles / VFD
    Last Post: 10-05-2015, 03:41 AM
  3. PC 7518 vs 1hp HSD 110v Spindle
    By firewire in forum Commercial CNC Wood Routers
    Last Post: 12-31-2014, 03:02 AM
  4. Servo for spindle, with 110v input?
    By aarongough in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2013, 02:23 PM
  5. Spindle motor and VFD for 110v
    By shadowless in forum CNC Machine Related Electronics
    Last Post: 03-26-2009, 04:51 AM
