586,042 active members*
3,730 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > CNC slant bed lathe - Boley BDN 160 to LinuxCNC conversion - live tool problem
    Apr 2016
    Unhappy CNC slant bed lathe - Boley BDN 160 to LinuxCNC conversion - live tool problem
    CNC slant bed lathe - Boley BDN 160 to LinixCNC conversion - live tool problem
    Dear CNCZone Users
    Last year I bought used machine with Sinumerik 3T/3M system.
    It was some problems with this system, and I decided to convert it to LinuxCNC.
    I am asking for help - with some hal code for live tool turret.
    This is Sauter 12 position turret with all driven stations. Model 0.5.480.316
    Does anyone have some sample of Hal code for linuxcnc with
    programing of such Turret and live tools to be working properly.
    I have found some clever buddy which help me with conversion, but problems has occured.
    He is able to set up
    Axis X and Z, engine, servos, encoders, but has some problems with programming live tools (driven tools)
    C-Axis (some sources use this name) to be working properly. Second problem is to change turret tool position
    (from posiotion No1 for instance to No2, or No5 or reverse)
    Here is all technical documentation I have to Boley BDN 160 slant bed lathe:
    https://www.dropbox.com/sh/fd5noeqew...nAkssX3qa?dl=0
    Please for help
    Best regards
    Marek Idzkowski
    Poland
    Sep 2010
    84
    Re: CNC slant bed lathe - Boley BDN 160 to LinuxCNC conversion - live tool problem
    Marek,
    You will get much better replies on the LinuxCNC forum with thousands of users to assist you.
    It helps a lot to state the version your using, what you did, what you expected and what you got as specific as possible.
    JT
    Apr 2016
    Thank You JT
    I will try with LinuxCNC forum
    Regards
    Marek
  1. Replies: 21
    Last Post: 12-16-2015, 11:27 AM
  2. G101 on Okuma lathe, live tool
    By emsee in forum Okuma
    Last Post: 07-19-2012, 10:49 PM
  3. Boley BC 32 lathe, encoder problem
    By buggsson in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2010, 02:03 PM
  4. lathe live tool in MC
    By cnc-king in forum Mastercam
    Last Post: 04-28-2008, 07:56 PM
  5. CNC Lathe Live Tool control
    By AKFALAR in forum OneCNC
    Last Post: 11-19-2006, 07:06 AM
