Does anyone know if the rapid speed , when G00 is called, can be changed with the parameters on an old LC30 with a OSP 3000 control? I cannot find anything about it and think maybe it can only be changed with the master tape. Thanks, Todd
if you lock the key on setup, G00 is only on 30%. Or i am wrong . Try
Not many parameters on a 3000. Think your stuck with the rapid override with single block only.
Sent from my A3-A20FHD using Tapatalk
