586,110 active members*
3,257 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Milacron Sabre 750 , VFS5 problem
Results 1 to 11 of 11
    Mar 2013
    59
    Hi all
    I tell them what happened!!!!
    there was a blackout of electric current ,low and quickly climbed 2 times.the switch was in position on.
    after the electric current was normalized turned on the machine and surprise, the control starts and loads fine but not power ( power required) I see the VFS5 Driver
    Now VFS5 LED.
    -Active llluminated.
    -System OK not llluminated.
    -CPU flashing.
    -Fault not llluminated
    then see this in other forum:
    Hello Udom,
    It sounds like the program is corrupt on your VFS5. A flashing CPU light means the spindle drive is stuck in autobaud. <Waiting to find the correct com port baud rate>
    Here is a link to the software to communicate with your spindle drive from Kollmorgen.
    404 - File or directory not found.
    The communications cable you need is 3 wires, NO more. End to end the com's cable wires as follows.
    Pins 2-3, 3-2, 5-5
    Hope this helps, just IM me if you have anymore specific questions. !
    Forgot to mention this before. If your CPU light is flashing you'll have to scan twice to find the drive normally. The first time locks the baudrate, the second scan should find it and talk.
    after making 2 scans,
    VFS5 Spindle drive LEDs are:
    ACTIVE: OFF
    OK SYS: on
    CPU: on
    FAULT: on
    now the machine can ON ,align all axis but when put command M3S1000 said waiting for spindle feedback then show "alarm Spindle Drive not ready"
    Attachment 318938
    I connect SR232 cable with motionlink plus and show this error's
    Attachment 318936
    NOTE: machine working fine before blackout of electric current
    I found this in manual kollmorgen
    ERROR 27 “R/D JUMPERS” SEVERITY 3
    Either the jumpers on your VECTORSTAR MC2 card are incorrectly set or the wrong TL has been loaded. Contact the factory
    ERROR 83 “BAD OR OUT OF RANGE” SEVERITY 2
    You entered a parameter to an instruction that was too large or too small. Check Appendix F for limits on variables. This
    error can also occur when a parameter is in the wrong format, such as a character string where a number is expected.
    This error breaks program execution if the instruction is issued from the user program.
    ERROR 84 “OUT OF BOUNDS” SEVERITY 2
    The variable listed is out of bounds. If the variable is protected (that is, set by the factory as defined in Appendix F),
    contact the factory. If the variable is not protected, set it within its bounds. This error breaks execution.
    any idea or recommendation ??
    Sep 2010
    1765
    Re: Cincinnati Milacron Sabre 750 , VFS5 problem
    WOW. Power outage while on did THIS?? Must have been big HI VOLTAGE spike when power went out!!
    error83 & 84 are either because YOU typed in bad commands in terminal window - DID YOU? LOOKS LIKE 11 TIMES?
    If not you, then it tells us the battery in BRAM memory chip is bad...
    R/D jumpers fault is because we have to set jumpers on drive inside to match the parameter RDRES: your fault says they are not set same (should be RDRES=12 for 12bit resolver)
    Flashing READY means your memory is bad too!
    We actually have the [majority] of default Saber 750 parameters and program stored in batt backed portion of the memory in drive AND IT IS LOADED EVERY TIME POWER IS APPLIED - with the internal command LOAD=1
    one such parameter is ABAUD=0 so READY LED does NOT flash and baud is set to IIRC 9600...
    So your power spike caused memory problems....
    c
    It MAY be that you can reload just the motor TL file and recover - since BOTH RDRES & ABAUD bbbkkkkkkkkkkkkkkkkkk
    Sep 2010
    1765
    my computer locked up.... continuing my reply....
    if any VARIABLES are lost, those are proprietary and thus I cannot sent the .var file or .bds file to you.... to reload those requires we get your drive and do it in our shop...
    if you check ABAUD & RDRES and reset them and it still does not work, email me mike at Kilroy Was Here dot com and I will email you back the .TL file for your machine.....
    Mar 2013
    59
    Quote Originally Posted by mike_Kilroy View Post
    thanks Mike for you fast reply!!!!
    yes I put bad commands ,is my first time that I used motionlink plus.
    I'll tell you as I have understood what to do, if I'm wrong you can tell me what I have to do and how to do it exactly, please
    open motionlink plus , go to terminal, type RDRES=12 enter , type ABAUD=0 enter . this is I need do ????
    thanks Again
    Sep 2010
    1765
    i sent you an email:
    Yes, BUT
    FIRST type in P RDres & P ABAUD to SEE what they are set to now!
    THEN correct them if needed.
    Since it is batt backed Ram, no need to 'save' them - just typing them in saves them.
    Attached is .TL file.... remember that motionlink is 20 yr old program so file names can only be 8.3 in size....
    how to load it?
    let me try to count steps:
    start motionlink plus
    when asked to BREAK program, pick YES
    click on CONFIG icon top
    click on OPEN on right
    pick the sample.tl file from where you copied it onto your hard drive
    click on XMT on right to SEND it to the VFS5 drive
    hour glass rotates showing it is busy going....
    When done, exit motionlink plus
    cycle power to VFS5 to restart it (not required to load new TL, it will be active immediately, but to RESTART the internal program -easiest way to explain how to do that)
    Hope that fixesw your problem - let us know...
    Mar 2013
    59
    Yes, BUT
    how to load it?
    hi mike
    I check P RDres and P abaud motionlink show : P RDres 94 and P abaud 0 . I put command rdres=12 enter motion link said ERR11 'RDRES' factory settable ,I check again but is same P RDres 94 and P abaud 0
    Attachment 319358
    Attachment 319360
    Attachment 319362
    how I can change RD res to 12??? or I'm not doing things right?? or load TL file that you send me??
    thanks
    Sep 2010
    1765
    did you try to load the TL file I sent? I believe it should load without password.
    sorry about forgetting that rdres needs a password to change.... how do we get around that? do you know free teamviewer? can I come over internet to your laptop running motionlink and do these things for you? (I am not allowed to give any passwords).
    Your rdres=94 indeed shows your drive got a hellova voltage spike that screwed up at least 1 variable. There may be more but we should try to get you past rdres first to see if that gets you running quickly.
    tell me if we can teamview.
    Mar 2013
    59
    Hi Mike
    this is actual TL file in drive:
    Attachment 319600
    Attachment 319602
    Attachment 319604
    I try to load TL file that you send me but not was possible.because when load the motionlink show some error example RD ( this tl file no have RDRES) ,ERR 208 'C12'
    this is TL file that send me :
    ;TL VFS5 v1.1.1
    MOTOR = V203ACN
    AMPS = 30
    VOLTS = 230
    ;UNITS:
    INUM = 4095
    IDEN = 100
    VNUM = 44740
    VDEN = 10
    ;TUNING VARIABLES:
    KP = 492
    KPROP = 5000
    KV = 2056
    KVI = 1000
    LPF = 1
    LPFHZ = 100
    ;PROTECTED VARIABLES:
    AMPS = 30
    ANGLD = 0
    BSLIP = 7650
    FOLDD = 100
    FOLDR = 900
    FOLDT = 200
    IBASE = 98
    ICONT = 45
    IMAX = 67
    IND = 1
    IZERO = 25
    MADV = 0
    MANG = 165
    MSLIP = 0
    POLES = 512
    SGOOSE = 0
    SLOPE = 41
    VADVTBL = 12500
    VBASE = 1500
    VMAX = 12000
    VOLTS = 230
    ERR 208 'C12' INTERNAL
    I modified the TL file original with parameters of you TL file , put RDRES and erase ERR 208 'C12' INTERNAL .
    this TL file modified was possible load and now P RDRES is 12
    see TL modified :
    ;TL VFS5 v1.0.3cC
    MOTOR = V203ACN
    AMPS = 30
    VOLTS = 230
    ;UNITS:
    INUM = 4095
    IDEN = 100
    VNUM = 44740
    VDEN = 10
    ;TUNING VARIABLES:
    KP = 492
    KPROP = 5000
    KV = 2056
    KVI = 1000
    LPF = 1
    LPFHZ = 100
    AMPS = 30
    ANGLD = 0
    BSLIP = 7650
    FOLDD = 100
    FOLDR = 900
    FOLDT = 200
    IBASE = 98
    ICONT = 45
    IMAX = 67
    IND = 1
    IZERO = 25
    MADV = 0
    MANG = 165
    MSLIP = 0
    POLES = 512
    RDRES = 12
    SGOOSE = 0
    SLOPE = 41
    VADVTBL = 12500
    VBASE = 1500
    VMAX = 12000
    VOLTS = 230
    then restart power but is same led on fault ,I check err hist
    Attachment 319608
    restart power and check err hist again
    Attachment 319610
    What else can I do?? what do you think??
    thanks for you support!!!
    Sep 2010
    1765
    The erro 208 C12 is common as last line and means nothing; not a problem.
    Yes, sounds like not only the .TL file waqs corrupted by your voltage spike, but also the program and its variables. I had hoped just a few were messed up but no luck.
    The program will need to be reloaded into the drive.
    Unfortunately we are not allowed by law to do that unless the drive is in our shop. Passwords and stuff needed. Sorry. Unless you want to send it to us to reload, I am afraid our hands are tied and we cannot help further.
    Mar 2013
    59
    thanks very much for you support!!!!!
    check you email i send request for you quote me program and variables reload .
    thanks again
    Mar 2010
    5
    If SRAM random value - Init on programator SRAM DS1230Y-200 all bytes zero
    on address sram 5672h - value voltage (if 230V- E6h 00h)
    on address sram 56B9h - value RDRES (12 0Ch)
    if loading tl voltage and RDRES not equal edit previos values - will be ERROR 18 “BAD TL”
    then restore you tl ,var ,bds prog
  1. Replies: 8
    Last Post: 04-04-2021, 07:33 PM
  2. Replies: 11
    Last Post: 07-31-2019, 07:01 PM
  3. Cincinnati Milacron Sabre 750 ERT parameter list
    By vdeprado in forum Cincinnati CNC
    Last Post: 11-09-2015, 04:42 PM
  4. Replies: 4
    Last Post: 12-10-2013, 04:36 PM
  5. Replies: 0
    Last Post: 03-06-2012, 04:31 AM
