586,075 active members*
3,831 visitors online*
Results 1 to 3 of 3
    Apr 2016
    3
    Question Heidenhain TNC310
    Hello everyone
    At work recently brought a Lagun mill with a Heidenhain TNC310 controller.It is our 1st CNC so we are learn as we go. We are able to move the X,Y and Z in manual mode but we cant turn the spindle on Does there need to be tool in the collett for this to work or is there a command that we are missing.
    Also is the datum stored when you turn the machine off. What is the easiest way to keep the datum in a certain place. We have read the manual but this doesn't seem to hold.
    Any help would be appreciated
    Thanks you
    Gareth
    Feb 2021
    7
    Re: Heidenhain TNC310
    Quote Originally Posted by Gareth76 View Post
    Hello everyone
    Thanks you
    Gareth
    There is a button that looks a circle with arrows pointing off it.Think its next to the coolant button.Press that first and then try to start the spindle and see if the spindle starts.Also does the machine have auto tool changer?
    Mar 2016
    325
    Anyway U should first input spindle speed data. In manual there is S softkey after presing it U can set the speed and confirm it with cycle start, NOT ENTER.
    Also in MDI u can write toolcall withn no values beside S parameter (which sest spindle speed) and in next line M3/M4.
    Tool is no needed to turn on the spindle.
  1. Replies: 0
    Last Post: 02-16-2016, 11:56 PM
  2. Interesting troubleshooting RE: Heidenhain TNC310
    By gus in forum Bridgeport / Hardinge Mills
    Last Post: 10-09-2007, 01:06 PM
  3. Heidenhain
    By kura in forum DNC Problems and Solutions
    Last Post: 06-28-2006, 12:24 PM
  4. Heidenhain 150 help
    By tom bryant in forum MetalWork Discussion
    Last Post: 05-19-2006, 03:53 AM
  5. Heidenhain TNC310 RS232
    By Al_The_Man in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-27-2005, 03:18 PM
