586,075 active members*
4,291 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Feb 2018
    5
    Dear Viorel
    I bought a maho mh700s with philips 432 from 1992(version of soft ware is 6701.703/03 ) , I want to use it in DNC mode , I have not any idea .
    please advice me how can I do it ?
    sorry for bad english
    many thanks
  2. #22
    Feb 2020
    4
    Olá preciso dos parâmetros maho 600C versão 6097/405.
    Quem poder me enviar agradeço.
  3. #23
    Feb 2020
    4
  4. #24
    Mar 2022
    Re: Maho Philips 432 answers
    Hello ,
    I work On a Decel Maho 800 e2 machine with Maho 432 control, the interesting thing is that it works with the G18 programming plane, but the Z axis is Y and the Y axis is Z, which is very confusing.
    I see that you asked a colleague if he changed the axis of the machine parameters, which makes me think that the same thing was done for me. If you can help me change this thing I will be very grateful.
    Greetings!
  5. #25
    Feb 2006
    12
    Old maho's are like this. It's because the horizontal milling spindle is seen as the main spindle, when viewing from this spindle the Y and Z axes are correct.
    The vertical spindle can be removed and is therefore seen as the secondary spindle, which is why the axes seem inverted when using this spindle.
    This cannot be changed in the control. You can switch from G18 to G17, but that just tells it to add tool lengths to the Z axis instead of the Y axis.
Page 2 of 2 12
  1. MAHO 900C with Philips CNC 432
    By ua_gs in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-24-2016, 09:51 AM
  2. PHILIPS 432 (MAHO MC50)
    By abbas in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-24-2009, 10:17 AM
  3. MAHO-PHILIPS 432 M60 and G23 problem
    By micktat in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-03-2009, 11:10 PM
  4. Maho 650 - CNC 532 Philips
    By nylas in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-13-2007, 07:41 PM
