603,545 active members*
2,902 visitors online*
    May 2007
    10
    Mach3 Macro for axis lubrication
    I edited the CS-Lab macro and would like to make sure I can use the function : GetTickCount() (microsoft function ?)
    The mill is an EMCO VMC-100.
    'lubrication MACRO using CNC4PC C-32 -imcomplete
    Const LastMsDRO = 1300 'DRO for data
    Const StateDRO = 1301 'DRO for data
    Dim CurrentMs As Long
    Dim LastMs As Long
    Dim State As Integer
    Const LubeTime = 100 'Lubrication time
    Const LubeWait = 200000 'Greasing interval
    Const OutLubePump = OUTPUT1 'Digital output C32 oil pump
    Sub Main
    'Read data
    'milliseconds that have elapsed since the system was started
    CurrentMs = GetTickCount()
    LastMs = GetUserDRO(LastMsDRO)
    State = GetUserDRO(StateDRO)
    If(CurrentMs < LastMs) Then
    State = 0
    End If
    Select Case State
    'Lubrication start
    Case 0
    ActivateSignal(OUTPUT1)
    LastMs = CurrentMs
    State = 1
    Message"Lubrication START !!!"
    Sleep(1000)
    DeActivateSignal(OUTPUT2)
    'Lubrication and stop
    Case 1
    If(CurrentMs > (LastMs + LubeTime)) Then
    LastMs = CurrentMs
    State = 2
    Message"Lubrication STOP !!!"
    End If
    'Wait for lubrication
    Case 2
    If(CurrentMs > (LastMs + LubeWait)) Then
    State = 0
    End If
    Case Else
    State = 0
    End Select
    'Data record
    SetUserDRO(StateDRO, State)
    SetUserDRO(LastMsDRO, LastMs)
    End
    Thanks!
    May 2007
    10
    Re: Mach3 Macro for axis lubrication
    The Macropump that is macropump.m1s file should be placed in „C:\Mach3\macros\name of the file we use” folder, so it could start running we have to only activate „Config\Generlal Config\Run Macro Pump” function and restart Mach3.
  1. ATC MACRO MACH3
    By Machinaria in forum Auto Tool Changer
    Last Post: 06-10-2017, 05:13 PM
  2. Custom Macro for Mach3
    By visual14cnc in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2015, 08:30 PM
  3. Another RF45 CNC Conversion - lubrication and Z axis
    By analogman in forum Benchtop Machines
    Last Post: 09-03-2014, 06:39 PM
  4. TL2 x axis lubrication problem
    By garylb in forum Haas Lathes
    Last Post: 10-08-2012, 03:27 PM
  5. Axis Lubrication - Multus
    By zooloader in forum Okuma
    Last Post: 08-18-2009, 04:02 AM
