586,058 active members*
4,275 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Need Help Please !! Hyundai-Kia VX500 Spindle V-Belt
Results 1 to 3 of 3
    May 2016
    Can anyone please help us. We have a Hyundai-Kia VX 500 machining centre that has snapped the V-Belt between the drive motor and the spindle. Can anyone offer any diagrams or manuals on how to change the V-Belt or does anyone know of a person we could contact to fix it for us. We are located in Wollongong, NSW Australia. Thanks in advance .. Dale
    Apr 2009
    1262
    Re: Need Help Please !! Hyundai-Kia VX500 Spindle V-Belt
    You should have a dealer in Brisbane Australia - check the website below.
    https://machine.hyundai-wia.com/usa/...DO=&S_SEARCH=Y
    Typically to replace the belts, you will loosen the spindle motor, slip off the old belts. You may need to disconnect spindle thru coolant and clamp cylinder hoses, etc. in order to get them completely off. Then re-install belts and re-connect what was disconnected. It's may not be a fun job, but you will save a lot of dough if you tackle it yourself. The belts will be fairly snug with about 7mm deflection when pushing hard with your fingers. If they squeak when starting and stopping the spindle, they are still too loose.
    Best regards,
    Mar 2023
    4
    Quote Originally Posted by OkumaWiz View Post
    https://machine.hyundai-wia.com/usa/...DO=&S_SEARCH=Ypaper io 2
    Best regards,
    The V-Belt on our Hyundai-Kia VX 500 machining center has broken between the drive motor and the spindle. Please share any instructions, manuals, or contacts you may have for someone who can change the V-Belt for us.
  1. RF-30 Spindle belt choices
    By martin_05 in forum Benchtop Machines
    Last Post: 03-17-2015, 04:57 PM
  2. spindle belt don't last
    By samu in forum Bridgeport / Hardinge Mills
    Last Post: 06-03-2013, 07:29 PM
  3. Hyundai HiT-18S Spindle Sleeve
    By CaseyCAM in forum Hyundai Kia
    Last Post: 09-21-2011, 04:43 PM
  4. SX3 2x spindle belt
    By PEU in forum Syil Products
    Last Post: 08-02-2008, 05:14 PM
  5. Kia Vx500 W/ Fanuc Control
    By tadlon in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2007, 05:49 AM
