Re: My new G0704 mill - give me your must do mods!
If you plan on using ball screws, handles won't work. The Z will most likely slide down, and you would have to lock the gibs for drilling, and for manual milling, the screws could back off.. Get yourself a $100.00 drill press.
Software wise, I prefer LinuxCNC. Don't do CAD/CAM on the Machine Controller. Use a laptop or desktop for that. Keep you Machine Controller as clean and simple as you can.
Originally Posted by
slakwhere
are you just setting a feed rate in the display and holding a feed direction digitally with a keyboard/pendant/mouse? that's for sure an option i guess, but i'd like to not even have to power up the computer just to take a pass or drill a hole. a manual machine sure is handy sometimes for non-critical operations.
i don't NEED longer travel, but if it's apart and fairly easy to do, i'm going to do it while it's apart. i know RusStuff on youtube didn't and really regrets it. it seems like a pretty low hanging fruit item.
would you say the belt drive for the spindle is easy enough to do later after sorting out the rest of the CNC stuff? or a big enough change that it should be done while the machine is apart for ball screws and steppers/servos?
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
