586,035 active members*
3,828 visitors online*
Results 1 to 6 of 6
    Mar 2016
    23
    New Omio Machines! Opinions?
    X6-2200 - CNC Desktop Engraver -omiocnc.com
    Omio has updated their line of cncs, it appears the most significant change is the controller.
    What does everyone think of the changes?
    Re: New Omio Machines! Opinions?
    Is this new controller compatible with Fusion 360 cam g code? One can select mach3 in Fusion, not omio....
    jan
    Oct 2015
    Quote Originally Posted by ecofablabbrugge View Post
    jan
    just for ppl searching for the same thing:
    no, its not. they say its fanuc compatible, but thats also not the case, the fanuc postprocessor needs to be modified to work at all. and even then, the thing doesnt understand G28, nor some of the other g or m commands that are supposed to be supported.
    i also found out that its a relabled DDSV1 from Digital DreamCNC
    google
    DS_DDCSV1_EN.pdf
    to find a manual. (not very helpful either) maybe someone will write a compatible postprocessor for fusion, but until then ill shelf that POS and go back to good old mach3
    Jul 2016
    Having the same problem fusion 360 post. Newbie at this cnc thing.
    Please do yourself a favor and read the whole thread about OMIO.
    You'll find all about the tolerances, about grounding the spindle being science fiction and about no real customer support.
    https://www.cnczone.com/forums/chine...are-forum.html
    1225
    Gosh a dis-satisfied customer new to the forum and rubbishing the Omio machine on several old threads he resurrected.
  1. Which one should I choose, omio x6 cnc or ox cnc kit?
    By rieu in forum Commercial CNC Wood Routers
    Last Post: 01-15-2016, 03:44 PM
  2. Replies: 0
    Last Post: 06-13-2015, 04:36 PM
  3. Comparing Machines, Looking For Your Thoughts or Opinions
    By Stoner in forum Commercial CNC Wood Routers
    Last Post: 07-31-2012, 02:46 AM
  4. Cincinnati Machines - Opinions?
    By TonyW in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2012, 03:22 PM
  5. Opinions on a couple machines
    By Myrmidon in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2010, 06:43 PM
