Originally Posted by
richardmg9
Ok, so I have changed my build quite a lot. I thought I had my build planned out and was just posting the concept here for troubleshooting. I have learned a lot from this forum, more than I expected, and my build is reflecting this.
I think I want to pass on steel fabrication in favor of epoxy granite. I am also now thinking a moving gantry would better suit me. I want to minimize machining requirements, and to that end I have come up with the following plan:
A flat rectangular base with both working area and gantry support area included. I plan to make the base from E/G and finish the top with self leveling epoxy. Next, I plan to make 2 gantry supports cast upside down with the feet finished in self leveling epoxy. The next step is to place the gantry supports upright and side by side on the center of the base and connect the tops with a temporary channel. This should allow me to cast self leveling epoxy on both gantry supports for a level and plumb rail support. I do plan to trim meniscus off the feet first. I plan to attach gantry supports to the bed with cast bolt anchors. I want to avoid adjustments on this connection.
For the gantry, I do not have a solid plan, but I am currently thinking a self leveling epoxy for the rail mounts again. I want the adjustments to square my gantry with my bed to be between the part connecting the gantry trucks and the gantry. ie: a single part connects 2 gantry support trucks per side, and the gantry is mounted to that part with adjustable bolts.
To summarize, I am proposing that I:
1) build a flat base with a self leveling surface
2) build gantry supports with self leveling feet
3) cast self leveling rail mounts on the gantry supports
4) use self leveling face on gantry for rail mounts
5) square gantry face to machine bed with bolts mounting gantry to it's guide trucks
That is the current general plan for the machine base. I have a few other thoughts to share:
I want both bolt holes and vacuum grid on my bed. I am thinking for part boltdown holes that I can cast them in the E/G a few mm above the surface, them cast the self leveling surface a few mm above them with some form of plug to provide an end product that is recessed. This is also the plan for the linear rail mounts. I would love some advice on how to get these sockets placed as square and vertically as possible. If a single bar of steel/aluminum with a machined face and milled threads is best, so be it, but I would prefer some method which allows me to cast "plugs".
For the vacuum bed, I was thinking that I could machine a grid into the self leveling epoxy as it is pure epoxy without the sand/gravel. Is a pure epoxy working surface a good idea? is it tough enough? can I cut a vacuum grid in it?
Speaking of general "tough enough", I want to machine any hardwood with no issue. I want aluminum machining to be as smooth as pine. Harder materials like steel would be a lovely plus as a fringe case with possible lubrication. I realize that I could make a reasonable aluminum/wood machine with 80/20, but I want to make the most capable machine I can. I plan(at the moment) to use linear servos eventually on this machine. My goal is accuracy over speed. Resolution is the parameter I wish to optimize.
A few questions I have failed to find answers to:
1) How critical is hole alignment for my linear rails? It seems as though the practice is to bolt one rail down tightly and slave the next to it with adjustments done by tapping and tightenting/losening. This leads me to believe that I do not have to get my rail mounting threads super accurate? How accurate should the mounting holes be? (I have read the THK mounting PFD) In other words: can I just measure as best as I can, then use a drill press on my MDF mould to mount my rail mounting sockets?
2) Are self leveling epoxies good enough to use the build method I have described? I think the proposed method with produce a square machine, but I am ignorant.
On to casting... I am trying to find methods that will allow for strong and dense castings. I see that aggregate grading and vibration are key issues. I do not want to buy vibrators. Spending 100$+ on tools just to make my castings is not acceptable. I have seen builds using manual tamping to get reasonable density. I like this method as it is free. That being said, I would like to make the best product I can. I had the idea of using a crappy-but-powerful second hand subwoofer. Is this a potential good idea?
Any thoughts, comments, criticisms, critiques, ect. are more than welcome. Tell me why my ideas are crap! Thank you for reading, and thank you for your comments.
