586,116 active members*
3,556 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Axis drive board led light help.
Results 1 to 6 of 6
    Jul 2014
    17
    I have a Journeyman 425 that quit working the other day. I checked the y axis board and the red led that says o/c is lit. Could anyone tell me what o/c is. I swapped the board to a different axis and the light is still on so I'm thinking it's the board. Thank for your help.
    Aug 2014
    889
    Re: Axis drive board led light help.
    O/C = Over Current
    Jul 2014
    17
    Thank you. Makes sense now. When I pulled the board I found the power wire for the servo motor was not installed correctly and had arced out against the standoff that holds the board. It looks like part of the board is burned up.
    Aug 2014
    889
    Brushed DC servo I imagine? Sometimes worn brushes will also throw the error out.
    Jul 2014
    17
    I tried to zero reference the machine and I got a "z servo error loss of feedback or no motion detected on z axis" alarm. I opened the cabinet and found the o/c led on. When I swapped the boards I found the loose wire. You can see where the wire arced in the pic. The other pic shows where the board looks to be burned. I found a board on ebay and should have it in a few days.
    Attachment 319530
    Attachment 319532
    Aug 2014
    889
    Good to know you have it under control. I hope it all works out for you.
  1. Replies: 1
    Last Post: 01-15-2011, 01:03 PM
  2. warning light on one drive
    By cwaugs in forum Viper Servo drives
    Last Post: 09-19-2009, 03:36 AM
  3. Maztrol M32 - No monitor display No drive light
    By nbodie in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-17-2008, 08:26 PM
  4. Breakout board - power light indicator?
    By MakotoKamui in forum Automation Technology Products
    Last Post: 03-24-2008, 05:45 PM
  5. Bosch Axis Drive Board Z15-1-240V
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 08-15-2007, 06:35 PM
