iPlasma 4x4 CNC Plasma Cutting Table with TB6600 CNC Controller ONLY $2500!!
IPlasma 2.0 4x4 CNC Plasma Table
Complete with motors, electronics, and software
Feature
? Steel bolt together frame for easy assembly
? Replaceable slats
? Igus cable track ($400 Value usually not included)
? Billet Aluminum machined Z-Axis
? Floating hand torch mount
? TB 6600 controller with (4) 300 in/oz 3.5 amp stepper motors
? 36v 350w power supply
? Controller and power supply is a plug-and-play system
Also included
? CD for Mach 3, Sheetcam, and Inkscape download (License required for Mach 3 and Sheetcam)
? TB 6600 manual
? adjustable feet
? Table installation instructions
**Digital Torch height control is not included but can be purchased on eBay for $250. The Proma THC 150 works with Mach 3.**
TABLE IS SHIPPED UNASSEMBLED TO A COMMERCIAL ADDRESS OR TERMINAL NEAR YOU!
Requirements
? Mach 3 License
? Sheetcam License
? Windows XP computer with parallel port
? Plasma cutter
For the quality you get from this plasma table you can't beat this price! There are hundreds of iPlasma CNC tables in the country right now (designed in 2012) so you can find videos all over YouTube, Google, etc.
This model iPlasma 2.0 has a few changes including different laser cut slats instead of the flat mild steel flat slats and also a controller and power supply mount on the corner of the table.
Call or Text Matt at 651-472-4509
List Date: 5/9/2016
For more info, click here to view the original listing: iPlasma 4x4 CNC Plasma Cutting Table with TB6600 CNC Controller ONLY $2500!!
On Sale For: $2,500.00
