586,076 active members*
3,783 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Open source low cost servomotor controller
Page 5 of 8 34567
Results 81 to 100 of 141
  1. #81
    Jun 2008
    467
    Re: Open source low cost servomotor controller
    jfong,
    Maybe the ID of a 8mm pulley can be bored to 9.525mm or 3/8"
    3M HTD3M 72T 18T Belt 15mm Timing Pulley Belt set kit Reduction Ratio 4:1 CNC | eBay
    I agree with you, it will cost more than the inexpensive motors we shop for.
    JoeyB
    Quote Originally Posted by jfong View Post
    Thanks for the link. I haven't seen that. Although I don't think the 15 tooth pulley has enough there to bore it out to fit my 8mm shaft. Probably why I choose 20 tooth at the time.
    Edit Some of my servo motors have 3/8" or larger shaft diameter. Getting a 4:1 pulley set that fits without spending $$ isn't easy. It costs more for the pulleys than the motor!!!
    A doughnut a day keeps the doctor away.
  2. #82
    Apr 2004
    733
    Quote Originally Posted by joeybagadonuts View Post
    jfong,
    JoeyB
    Oh ya!! I have to look up that pulley size on stock drive products website. They give you CAD drawings of all the gears and pulleys they sell. From there I can see if there is enough to bore it out larger. So much cheaper on eBay. Thanks....
  3. #83
    Jun 2008
    467
    jfong,
    I believe the HTD5M would be more appropriate for your large motor due to the KW rating.
    HTD5M 48/12 Teeth W-21mm Pitch-5mm Timing Pulley Belt set kit Reducer Ratio 4:1
    JoeyB
  4. #84
    Apr 2004
    733
    Quote Originally Posted by 109jb View Post
    A few questions I have about the drive:
    1. It uses a battery as a reserve for high load motions to stabilize the bus voltage. I think this is a pretty smart way of doing it, butt the battery linked on the Odrive page shows a 3S Lipo, does it have to be a 3s Lipo battery or can other size/type batteries be used. For example, a 12V car/motorcycle/lawn tractor battery?
    2. If it has to be a Lipo, is there protection from overcharging? I have seen Lipo batteries combust and it isn't pretty
    3. The documentation says that the bus voltage is 24V. Is the system using a step up converter to achieve this?
    My brother makes e-bikes using larger RC brushless motors and big lipo packs. He uses high current 12volt Dell server power supplies in series to charge them. I think these power supplies are around 40-50amps and can be bought on eBay for $10 each. One way to to get the high current demand that these RC brushless require.
  5. #85
    Jun 2010
    4256
    By and large the GT2 belts will transmit quite enough power. I use them. When used on a 3D printer they are working at something lke 1% capacity. 6 mm wide belts are very easy to come by; 9 mm are harder. That said, the Chinese version of the GT2 profile is NOT the same as the original Gates design. How well they would mix - I don't know.
    But the big thing about toothed belts is that the GT2 design is effectively free of backlash, while the original ones (X, L etc) are NOT. The HTD design is certainly better than the older sort-of rectangular ones, but I am not sure how good. It has rounded teeth, which is better. But the 5 mm pitch is coarser than the GT2 2 mm pitch, which makes for more 'noise' in the rotation with small pulleys.
    Cheers
    Roger
  6. #86
    Jun 2008
    467
    Post Re: Open source low cost servomotor controller
    Fellow CNCer's, "Cake-Nibbling-Customers"
    Here are some belt torque rating spec's for future reference.
    JoeyB
  7. #87
    1943
    I understand this and I myself use Lipo batteries as I am an avid RCer. Lipo batteries are great for model airplanes, or even electric bikes because they have high storage density. However my milling machine will never fly, so I don't need high storage density. My concern is safety. Your brother may charge with simple power supplies, but if he ever had a first hand runaway of a Lipo battery he probably wouldn't. I had a 1500 mAh 3S lipo catch fire while charging and lost a work bench and could have easily lost a house had I not got to it in time. I still use Lipos for my airplanes but now use fire resistant charging bags, better chargers, and a steel box that the batteries are placed in while charging. I take charging of Lipo batteries very seriously. If the driver here doesn't absolutely need to use a Lipo battery then I won't use a Lipo.
  8. #88
    Apr 2004
    733
    I hear ya. He knows first hand how much damage a Lipo fire can do. He's been flying r/c since early 80's. gas now electric.
    What I am saying is don't use any batteries at all and use high current power supplies for the driver.
    He bought a expensive lipo charge controller after the fire. I believe he still uses the dell supplies as the power source for the charge controller.
  9. #89
    Jul 2012
    106
    This 6,000 r.p.m. encoder also looks promising and can be found for $25.00 or less.
    See the data sheet for more info.
    JoeyB
    The last encoder is intended for use on a large inertia <3,500RPM keyed shaft motor where the shaft DIA is >30mm or for example belt driven from a lathe spindle.
    Roger,
    Will the encoders I posted work reliably within the r.p.m. limitations of a 5tpi ballscrew?
    JoeyB
    Quote Originally Posted by macdowswe View Post
    Thanks for the heads up.
    I have tried to make sure that there is as much copper as possible in the current path that is expected to carry the motor current. The copper track impedance going around the motor current loop is approximately 1 milli ohm. This is 5 times smaller than the impedance through the MOSFETs in the same current path, so hopefully the amount of copper should be fine.
    I have designed the board so that you can add a single heatsink for all the MOSFETs. There is also a thermistor placed as close as possible to each of the MOSFET group (3 thermistors total). The control algorithms will also have thermal control, so hopefully it should be fine with the current design. Of course if it turns out that things get too hot, we can always beef up the tracks at the cost of a larger PCB, or thicker copper at the cost of price.
    3oz copper PCB isn't expensive and would impact your per unit cost by about $0.25 at most and still be less than $5.00/ea with FR4, 1.8mm, HASL, Blue/White board.
    How a pad is situated on the trace along with transitions along it's path are also important and you have to pay attention for current loops and ground loops on voltage and ground traces.
  10. #90
    1943
    Oh. Sorry I misunderstood. I actually kind of like the idea of having a battery for the reserve allowing use of a relatively small PS otherwise. Just hoping it can be done with a lead-acid battery.
  11. #91
    Apr 2004
    733
    I don't see why it wouldn't work since the peak current for these motors are 53amps. Industrial servo motors peak currents are only for a few seconds. The datasheet typical gives you time/heat duration for current peak. The Applied Motion/Copley brushless servo drives that I use, have a programmable peak current time setting. I set them around 1/2second and then it drops the current down to continuous current rating. It protects the motors from over heating if a axis stalls etc.
    I'm not sure if the odrive does that but it should. Anyone know what the typical continuous current rating for this RC brushless motor is. The brushless motors I have, continuous current ratings are around 1/4 of peak value.
  12. #92
    May 2016
    41
    That would likely be pushing that little motor to its limits during accel.
    If you want more power, you can simply get a bigger motor ;D
    I know we have beed using the ~1Nm motor as an example, but you can get something like this motor (link), which should happily do 4Nm.
  13. #93
    May 2016
    41
    So in the project page I link to this (link) battery, which is a 6S Lipo. However, you can run with any battery you want: 6S LiPo, 3S LiPo, 12V car battery, 24V two-car-batteries-in-series. Basically anything as long as the bus voltage doesn't go much over 25-ish volts, and the motor top speed will be scaled down if you use a lower voltge. There is voltage measurement on the DC bus which should be accurate enough to prevent overcharge. But that's not all, you can actually run the ODrive in two different topologies.
    The first one is the one is the one that I presented in the project page, which is to have the battery connected to the DC bus. This means the bus voltage is the battery voltage, and we can draw current by discharging the battery, or we can dump decelleration energy into the battery by charging it. There is a DC-DC converter that can be used as a step-up (with the addition of an external power-inductor) to charge the battery from a power supply with a lower voltage than the battery/DC bus voltage. So a fairly good setup would be a 24V (car or lipo, your choice) battery on the DC bus, and an inexpensive 12V power supply on the step-up input.
    The other topology is to have a power supply connected directly on the DC bus. This is what was running on the ODrive v2 demos. In this case, we can connect anything to the DC-DC converter. We could connect a power inductor and a lower voltage battery here, although I would say that the other topology is more efficient when using a battery. More importantly, we can just simply connect a power resistor to dump decelleration energy into. So basically, the power comes from the power supply directly, and we dump braking energy into a power resistor (this is also called a brake chopper in some terminology), and we don't need to worry about managing a battery.
  14. #94
    May 2016
    41
    JoeyB
    Wow I wasn't aware that GT2 5mm can handle so much! Thx for the reference! ;D
  15. #95
    May 2016
    41
    Yeah it will have thermal control as part of the motor control algorithm. I think the best way would be to have a thermal model of the motor, but if that's not available, a simple time-based backoff could be implemented.
    The current ratings given on these hobby motors are very ambigous. They don't state wether it is peak or continous (the way it is presented makes it seem like it is continous, but it is never explicitly stated). Also, they all have a fan on the rotor which cools the stator. But this only works when the motor is spinning, and for a CNC type of application, we may be loading it when it is not spinning (this never happens when spinning a propeller). Basically the current ratings given are very approximate.
    So I think that the best way to deal with this is to bury a thermistor in the windings and maybe also add an external cooling fan. With this we can either run the thermal control with the thermistor as feedback, or we could even gather data for a thermal model for that specific motor, so that others may use this motor but without having to add the thermistor.
  16. #96
    Jul 2012
    106
    I pulled the prop off my china Aerodrive SK3 6364-245kv clone and attached it to my dyno, the motor is 2.7KW/245KV output power (input power = max 37VDC@70A) and spins at 40KRPM no load at 32V/15.8A and delivered 6.84Nm, the one you show is 2.25KW/149kv and guessing will give around 6Nm.
    You're driver wont power it to get the torque you want and a drive reduction to see <3K RPM for linear motion would kill any machine precision unless you used expensive zero backlash gearboxes or large high power harmonic drives (way too expensive for hobby/home use) because belts will stretch and distort and plastic gears will explode due to inertia at those speeds and power levels and the thought of HTD8M x 50mm wide belts and pulleys would be bulky and extremely noisy not counting the lack of precision from stretch and bounce.
    I would prefer a more appropriate motor around 500W@3KRPM which gives you 1.5Nm and is more than sufficient to drive a BT20 mill utilizing linear rails (least amount of drag linear motion platform) at 590IPM, I have 600W BLDC 60V@4KRPM motors that delivers 1.9Nm on an ISO20 turcite coated dovetail machine and 750W BLDC 60V@3KRPM motors that delivers 2.4Nm on a small BT30 hard way machine.
    One of the issues I see with machine design and conversions is motor selection and power, example, my steppers deliver 3.7Nm @300RPM (turn faster reduces power, at 2KRPM it's about 0.09Nm) and my servos are rated at 1.5Nm so the general conclusion is the steppers have more power and this is incorrect, steppers are rated at peak power, servos rated at nominal power, the peak on my 500W servos is 4.56Nm and my 600W servos have a peak of 5.78Nm and my 750W servos have a peak of 7.3Nm, now which is more powerful?
    During some preliminary testing I have found that 250W motors (0.8Nm/2.43Nm peak) deliver enough power for a linear rail machine to cut stainless smoothly and unless you're driving a large DIA endmill (1in and larger) it shouldn't have any issues cutting most material at reasonable speeds and feeds provided the spindle has sufficient power to cut the material, 800W or 1KW (1HP to 1.25HP) wont cut it and 1.5KW (2HP is the minimum I would recommend) and there is a difference between input power rating which most motors are rated as and output power which most real spindle motors are rated by (2.2KWinput = 1.5KW output) so your 1.5KW water cooled spindle is really only 1KW and OK for aluminum, wood and plastic in shallow cuts if you expect to move the head at some speed.
    Regardless of the motor requirements, what is needed is an inexpensive driver system and it is my opinion that ODrive can be that driver.
    Ideally I think a single, dual and triple stage driver would be sufficient to configure just about any machine from 1-axis to 9axis or you could just do 2-axis, 3-axis and 4-axis drivers and call it a day.
    So, have you given any thought to adding the MAX3097ECSE for direct connect and encoder input flexibility and also to take advantage of encoder signal error detection?
    Here is a plugin schematic, works will all A/B/Z encoders,
    for single line encoders you would connect all - lines to GND,
    operates from 3.3VDC, can also use MAX3098ECSE.
    Attachment 344242
  17. #97
    Jun 2010
    4256
    Agree.
    The brushed DC servos on my machine are rated at about about 300 W with a 3:1 GT2 reduction onto a ~5 mm ball screw. I can't stall them.
    The spindle motor is an industrial brushed DC motor RATED at about 500 W, and i have never stalled that either. Mind you, industrial DC motors are kinda rugged - I went 'oops' one time when I found it was taking ~1.5 kW for drilling titanium.
    Merry Xmas
    Roger
  18. #98
    1943
    So the RC motors being discussed are about 1kW, but at 7000 rpm, so at 3500 rpm they are going to be 500W. Simple math tells us this. If you want to de-rate them to 500W at 3500 rpm there is nothing to say you can't. It would be easier on the motors. They are also very compact, so I would consider them a good choice.
    What is the talk about belt reduction drives not being a good choice and causing lost precision, belt stretch, etc? Timing belt reductions have been used on these kind of applications for a long time and they have proven reliability and positioning precision is not an issue in a proper belt reduction system. With a 3600 rpm max at the motor, with 3mm pitch GT3 belts you could use a 15mm wide belt and it would handle about 600W of power. 15mm wide, not 55mm, and not HTD. At higher RPM you can still use the 15mm wide GT3, you just are a little limited on the small pulley diameter. GT3 belts handle more power and have a profile that is essentially zero backlash and much quieter than an HTD tooth profile. Nobody ever said anything about plastic timing belt pulleys either. Aluminum timing pulley are the norm and are readily available. The whole notion of belt stretch affecting precision to any degree is a bunch of hogwash.
  19. #99
    May 2016
    41
    Quote Originally Posted by websrvr View Post
    Yeah I thought about it. I haven't really seen any low cost encoders that have differential signalling (without adding a differential tx yourself ofc). If more people request it, I can put it on, but I am very conscious about keeping the part count to the minimum for cost reasons. If your application requires interfacing to differential encoder signals, you can make a small breakout for that chip and add it right before the single ended inputs to the ODrive.
  20. #100
    Jun 2010
    4256
    They might be 1 kW - for 10 seconds. But when you are machining for 3 hours straight, I can't help feeling that those tiny-very-low-thermal-mass RC motors might melt down. The 500 W industrial DC motor I am talking about probably weighs about 10 kg! Heating that up takes a long time.
    And I agree 100% about the GT2/3 belts.
    (On Z axis. Baldor DC spindle motor in background.)
    Cheers
    Roger
Page 5 of 8 34567
  1. Replies: 31
    Last Post: 08-24-2015, 10:03 AM
  2. Smoothie CNC controller, Open Source.
    By Rolf_K in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-15-2015, 07:41 PM
  3. CNC Controller with Arduino - open source
    By Christian Knüll in forum Open Source Controller Boards
    Last Post: 12-22-2012, 10:46 AM
  4. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  5. BEST Open source Controller ?
    By Seventeen in forum Open Source Controller Boards
    Last Post: 09-22-2005, 12:27 AM
