586,533 active members*
2,897 visitors online*
Page 5 of 5 345
Results 81 to 91 of 91
  1. #81
    Feb 2014
    187
    Re: Bridgeport Manual to CNC Conversion...
    Anyone here running a BR2J head at 4000 rpm?
    I've wound my inverter up to 133Hz which gives 4000 rpm but didn't want to risk damage.
    Seems the spec sheets show 2300 or 4200 rpm - is there a difference in models here?
  2. #82
    May 2018
    11
    Hi!!
    Anyone in this forum with Bridgeport milling machine have this measurement from y axis bearing assembly bracket ... attached photo with "???????"
    Thank you in advance
  3. #83
    Feb 2014
    187
    The larger dimension is approximately 40.6mm and the smaller 37.4mm
    These were taken from my motor mount plate cad file but i may have filed them to fit later on so i cant be 100% certain the are correct
  4. #84
    May 2018
    11
    Quote Originally Posted by davek0974 View Post
    Another guy in this forum Willliam says that is the larger dimensions 42,50mm approximately and the smaller is 35,60mm ...
    Beacuse I can’t find the correct data
    I decided to take off the bearing bracket and take a measurement !!!
  5. #85
    Feb 2014
    187
    Its probably the best way
  6. #86
    Jul 2018
    58
    Got the limits and home switch fitted today, moving switches and fixed cams so I could do it all with two switches
    Top switch is limit and bottom is home.
    Attachment 384708
    had to alter my plan of homing to top as with the vise fitted the bed will crash...
    Attachment 384710
    All the way down, a lot of cranking....
    Attachment 384712
    Wired the limit switch into the loop, just the home to take back to cabinet...
    Attachment 384714
    wow that z axis looks interesting I went very basic.
  7. #87
    Feb 2014
    187
    It should work, lots of ways to do this.
    Watch out for backlash in the quill rack/pinion, might not be an issue but good to remember.
  8. #88
    Sep 2008
    157
    My conversion cutting steel plate shows the Z axis in action
    https://youtu.be/fVrYtKS9aeE
  9. #89
    Sep 2008
    157
    I can not see the video I have posted above and others have gone the same way on my thread? Can anyone see it? What has gone wrong?
    Cheers John
  10. #90
    Feb 2014
    187
    Quote Originally Posted by BMSTECH View Post
    Very nice, that Z drive is the way i should have gone, about as tight as it can get i reckon.
    Cube looks good too.
  11. #91
    Dec 2006
    87
    I started doing this around 20 years ago, here is a photo of one I did, this is very modified Head, that is 5" shorter than the standard Bridgeport Head
    that is SWEET !!
Page 5 of 5 345
  1. Clausing Colchester manual lathe conversion to CNC (keep manual also)
    By 86turbodsl in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2014, 01:50 PM
  2. CNC - Manual Lathe Conversion
    By multivitamins in forum Uncategorised MetalWorking Machines
    Last Post: 06-18-2014, 04:21 PM
  3. Manual lathe conversion to CNC -
    By jdmech in forum Uncategorised MetalWorking Machines
    Last Post: 10-02-2006, 10:32 PM
  4. Manual lathe CNC conversion
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2005, 09:56 PM
  5. Manual EDM to CNC conversion
    By Jim Estes in forum Waterjet General Topics
    Last Post: 03-15-2005, 02:06 PM
