586,096 active members*
3,378 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > C-axis error 8 motor overload
    May 2016
    We have a Fadal VMC 15 w/ ridged tap. I keep getting a "C-axis fault motor overload #8" which is spindle magnet not detected or spindle not running (which it is running). I have replaced the hall effect switch, encoder and the c axis board (1010-4) to no avail. I can't imagine it's the drive as we replaced it6 months ago. I have verified correct gap on hall effect switch, verified correct voltage and also checked in the diagnostics screen that the bit changes from 00 to 01 when the magnet is rotated under the hall effect switch. Though it will only change when rotated VERY slowly by hand, it wilI NOT change if rotated fast even by hand. have also ohmmed out each wire from the J10 molex plug to the hall effect switch and they are good.
    Apr 2005
    1194
    Re: C-axis error 8 motor overload
    Orient changing is a function of the switch and how it triggers on the dip in the diameter of the sensor hub on the spindle.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Mar 2016
    40
    It only happens during rigid tap or it happens with an M3 programmed? What kind of inverter is in there?
    Quote Originally Posted by fallsfab View Post
  1. Error 55 motor overload (T1)
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-27-2019, 01:05 PM
  2. x Axis Motor Overload Error
    By vertcnc in forum Fadal
    Last Post: 01-22-2016, 03:19 AM
  3. error #8 motor overload
    By charliemisa in forum Fadal
    Last Post: 04-07-2010, 05:19 AM
  4. Error #10 Motor Overload
    By emt2688 in forum Fadal
    Last Post: 11-19-2009, 04:05 AM
  5. C Axis Fault Motor Overload Error #27
    By wdwrd68 in forum Fadal
    Last Post: 10-11-2009, 12:07 AM
