586,112 active members*
3,102 visitors online*
Results 1 to 5 of 5
    Oct 2005
    169
    Question Haas VF5-XT Column Squaring
    We recently purchased a used 2012 VF5/50 XT. The previous owner had a crash and the machine was out of square from X-Y and from Z-X. We were able to square X-Y by adjusting the linear rails, but we are not quIte sure how to square the Z-X. While running in indicator up and down a cylindrical square, the Z is out about .005" per foot in the X direction. We checked the Z Axis rails with shim to see if they were up against the shoulders machined in the casting and it appears they are. Does this mean the whole column is out of square? Any Ideas on how to square this thing properly?
    Attachment 319698
    Oct 2005
    169
    Re: Haas VF5-XT Column Squaring
    We discovered some twist in the leveling. It looks good both directions when the table is on center, but it twists when jogging the table to one side or the other. Going to re-level the machine and see if that corrects this.
    Nov 2009
    23
    Is it bolted down to the floor, or just sitting there? I know you can "tweak" cast iron frames by clamping each corner down to ensure it tightly contacts the leveling pad. Also a large block in the middle of the frame while clamping the ends of the frame can make it stand up straighter.
    Also, have you called Haas? They may be able to help you, or at least point you in the right direction.
    Oct 2005
    169
    It is just sitting on pads not anchored. We ended up getting it straightened out. I was surprised the leveling could make that much of a difference. It is w/in about .0005" on the square now. I am curious to see if it will stay good over time or if it will settle seeing as how it is not bolted to the floor. The floor is new also so that may settle over time.
    Feb 2010
    1184
    Quote Originally Posted by beezerlm View Post
    I would certainly check it again after 6 and 12 months time. Sooner if you notice any issues. Glad it was an easy fix for you.
  1. Squaring RHS
    By laserpilot in forum DIY CNC Router Table Machines
    Last Post: 10-09-2014, 10:35 PM
  2. squaring up an IH clone
    By cyclestart in forum Benchtop Machines
    Last Post: 08-22-2011, 05:09 AM
  3. Squaring the Column of Your Mill
    By BobWarfield in forum Charter Oak Automation Support Forum
    Last Post: 05-31-2009, 05:26 PM
  4. Squaring the IH mill
    By QSIMDO in forum Charter Oak Automation Support Forum
    Last Post: 09-02-2006, 02:25 PM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
