586,104 active members*
3,371 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 4020 won't go into Cold Start . "Error- Enter Again or Hit Manual to Exit"
Results 1 to 8 of 8
    Jun 2006
    31
    I searched and couldn't find anything so I'm looking for help. This is a 1995 4020 in good shape. The machine was running perfect when we shut it down to move the company this spring. Connected the machine back up at our new location and now we have problems. The screen is mostly green and reads this message after hitting the green button on startup "Error- Enter Again or Hit Manual to Exit". It does not respond to any keyboard input. I've attached a picture. Also, the 1400-4 and 1030-1 boards are not lit up. Any ideas?
    Nov 2003
    287
    Re: 4020 won't go into Cold Start . "Error- Enter Again or Hit Manual to Exit"
    The first thing I would do is power down an try re-seating all the cards. Vibrations from moving may have shifted something.
    Jun 2006
    31
    Tried re-seating all the cards. Inspected for loose connections...nothing found. Tested voltages on power supplies and all seemed OK.
    The 1400-4 had a dead battery backup. Replaced battery. Still doing the same. Is there a way to directly enter diagnostics? The backup battery was completely shot and I'm wondering if the memory is junk.
    Jun 2006
    31
    I think I have fixed this issue. I replaced the Lithium battery on the 1400-4 board. I then entered diagnostics by jumping the J2 pin on the 1400-4 board. After running some memory tests and diagnostics (which everything passed), I did a "Zero Memory" procedure. Re-entered the SETP parameters. Everything seems good now. I haven't tried to run a program yet, but all seems normal.
    Feb 2012
    7
    Hi, I'm having the exact same issue and I checked the 1400-2 board ( that's the one we have) and I can't find the J2 pin, I don't know which one is it.. hope you can help me out. Even though it's been a long time from this posts...
    Thank you!
    Jun 2006
    31
    I'm not familiar with the 1400-2 board. However, what I did above fixed my problem. You'll have to find a way to enter the diagnostics. I think I found the instructions in one of my manuals. Or I may have pulled it off a service PDF online. Maybe someone else in here can help you further. The dead lithium battery was responsible for the lost parameters. Replace that first.
    Feb 2012
    7
    Quote Originally Posted by jlembas View Post
    Thank you! I already replace the battery, now I’m finding a way to get to the diagnostics page, the 1400-2 should be almost the same that yours, is there’s a label on yours that says J2? I tried the maintenance and operation manuals but I haven’t find the way to do it.
    Jun 2006
    31
    Yes. You have to slide the board out to see the jumper. it is labeled. 2 Small pins.
  1. "Enter a Number" error when staring ESPRIT
    By Tolyatti in forum Esprit
    Last Post: 10-07-2020, 11:15 PM
  2. Replies: 14
    Last Post: 10-15-2015, 04:27 AM
  3. Pressing "Enter" Makes Cycle Start on Mach3
    By Sekocan in forum Mach Software (ArtSoft software)
    Last Post: 05-14-2014, 03:55 PM
  4. Boring a 1-3/8" hole on a 5/8" thick 3"x3" cold rolled steel bar
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 05-14-2014, 02:49 AM
  5. 4020 fadal cant get past "Cold Start"
    By chipsahoy in forum Fadal
    Last Post: 03-08-2006, 01:29 AM
