586,117 active members*
3,566 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Viper 200 Servo Drives with Linuxcnc
Results 1 to 7 of 7
    Mar 2005
    271
    I'm thinking about making the switch to Linuxcnc for a more stable control. My question is will the Viper 200 servo drives be able to run with it in a closed loop.
    I do have us digital encoders on the servo motors.
    Thanks Mike
    Feb 2007
    966
    Re: Viper 200 Servo Drives with Linuxcnc
    The viper will only accept step/dir input. It can't be used as just an amplifier. Linixcnc does output step./dir though.
    I have found Mach 3 is stable if you use an older (xp/win7-32) Dell or HP computer with a printer port. What problems have you found with mach 3/4 ?
    Larry
    Mar 2005
    271
    Quote Originally Posted by Larken View Post
    Larry
    I'm still in the process of setting up my mill I'm just going by what I have read that linuxcnc is more stable control.
    Aug 2014
    889
    Close the loop to the controller via the encoders. The Viper 200 doesn't care much about what the encoders have to report back other than detecting missed steps and reporting over current faults etc... Its job really is to output when recieving commanded steps. Your controller is the one that will be making any adjustments by monitoring the encoder/feedback. So no problem provided your controller can adjust.
    Mar 2005
    271
    Quote Originally Posted by G59 View Post
    Sweet thanks G59.
    Feb 2007
    966
    What ?? Sorry, G59, but thats totally wrong ! ( Who the heck told you that ?? )
    The Viper is a closed loop drive and of course needs the encoder to close the PID loop that it updates thousands of times a second.
    Larry K
    Aug 2014
    889
    What I meant to say. Connect the Viper drive as needed (per instructions), but feed your controller the encoder pulses also. This now gives the controller a say in what is going on and not just the drive's PID.
    I'm glad it only took you a week to clarify this.
    Thanks anyways.
  1. Replies: 0
    Last Post: 07-27-2015, 08:37 PM
  2. Techno Servo retrofit with Viper drives
    By Larken in forum Techno CNC
    Last Post: 08-01-2013, 06:45 PM
  3. repairing viper drives.
    By najnielkp in forum Viper Servo drives
    Last Post: 01-20-2012, 04:09 PM
  4. Viper 75/95 servo drives support
    By Larken in forum Automation Technology Products
    Last Post: 11-15-2011, 06:51 AM
  5. New 300 Khz Viper drives
    By Larken in forum Viper Servo drives
    Last Post: 04-07-2010, 02:14 PM
