Hi.
Is there a way to programme multiple cuts and where would it be done?
as an example if i wanted to cut 12 small rectangular blocks at the moment (newbie) i would toolpath a single block and then when cutting, advance the x or y zero at the end of each block and press start again.
It seems awkward to set up a single job with the twelve blocks - i could do it - but also it seems a waste of time to cut ,reset, cut reset etc etc
I would appreciate any advice on this.
Rob.
