586,071 active members*
4,163 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Calibrating movement on custom laser cutter with Lihuiyu Studio and Corellaser
Results 1 to 7 of 7
    Mar 2016
    8
    Hello!
    We have a custom laser cutter that works with Lihuiyu Studio Labs controller and seems like only with Corellaser software.
    And I have an extreme problem with calibration on both axis.
    If I draw a square 10x10 mm, the laser cuts 22x22 mm.
    I couldn`t find the way to fix this in settings of Corellaser.
    Maybe someone has any experience with these controllers? Or maybe it can work with some other software?
    Apr 2016
    62
    Re: Calibrating movement on custom laser cutter with Lihuiyu Studio and Corellaser
    I replaced the controller with an Arduino Mega and Ramps board...
    Mar 2016
    8
    Seems like you did the right thing!
    Apr 2016
    62
    Well for me it was planned already before I bought the machine as all reviews on these controllers and software turned out to be bad at best.
    Does not matter if it runs on a fake Corel software or with the Moshi software, they are user-unfriendly and limit what the hardware can do.
    Plus it totally failed to see the point in having a dongle for a machine that would only work with this crappy software to start with.
    But if you need a controller I have a spare one, was only used for a few minutes to confirm the hardware actually works LOL
    Jul 2016
    Hullo Downunder35m. Is it an easy conversion...as in unplug the other board and plug everything in and then install/run another software in lieu of what came with the old board? Any help would be appreciated. I'm at a crossroad at the moment and not too sure what the problem is... I think it could be the stepper motor but everything looks right so when I stumbled on this thread I'm now thinking it may be the board. Problem with my laser cutter is that when it cuts... the lines are not straight. The circles are even worse.... if you draw a straight line then turns a 90 degree to another line.... that second line looks like a heartbeat scan until it eases to the straight line.
    Again any help is appreciated.
    Jul 2019
    Quote Originally Posted by Downunder35m View Post
    Hi there,
    Which software does this particular controller use, please?
    hi My friend
    please try corel laser first icon on the top of left which you put serial number
    there is as may be third number about resulation it changes calibrate
    Ayd?n
    about plt you must from corel export in side page plotter units
    resulation change raster size
    plotter un?ts change vector size
    Aydin
  1. Calibrating X and Y axis on 4060 China laser engraving/cutting machine.
    By doken in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-17-2021, 09:31 AM
  2. Replies: 1
    Last Post: 06-15-2016, 07:15 AM
  3. Replies: 0
    Last Post: 02-29-2016, 09:13 AM
  4. calibrating cnc using nc studio
    By nvis in forum Chinese Machines
    Last Post: 09-03-2014, 01:54 PM
  5. Custom Cutter Profiles?
    By declanhalpin in forum MadCAM
    Last Post: 03-19-2013, 10:33 AM
