I’ve been reading this great forum for over a year now and planning a router for a while. I’m going to use it mainly for wood, but it would be nice to be able to cut aluminum.
Working area about 1100x800x140 mm. Frame is mainly steel because of strength and low price. Y-axis car and Z-axis are made of aluminum.
My budget is very limited, but I got rails and ball screws at good price. I’m planning to make strong enough frame. Other parts can be updated later if needed, such as controller, router, motors and drivers.
At first I’m going to use Bosch POF 1200 AE router, Arduino GRBL as controller
The frame is bolted together, no welds. Mostly 5 mm thick wall, but some parts that doesn’t need threading are 3 or 4 mm. I’m going to use epoxy to level base for rails and also use it to flat all connecting surfaces before bolting. For Z-axis rails base I have aluminum bars, shown in pictures.
Parts that I already have:
Rails are 20 mm THK profile rails for all axis.
Two identical 2010 ball screws, lenght 1200 mm for x-axis.
One about 200 mm 1605 ball screw.
Four Wantai Nema 23 425oz.in, 3.8mH.
Four PiBot stepper drivers PiBot Stepper Motor Driver Rev2.2 (Compatible Many Boards Output 4.5A)
Two power supplies 40-60 V, 25 A.
Cabinet for electronics.
Some parts of aluminum and steel tubes.
Bosch POF 1200 AE router.
I have only some basic tools to work with:
Small drill press, miter saw, angle grinder and track saw. Maybe access to lathe.
In pictures the gantry is 200x100x6 mm. Will it be strong enough compared to rest of the design?
How high and low should the router be able to move with regular bits?
Any thoughts about the design?
