586,113 active members*
3,259 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Compensating for laser beam width during cut
Results 1 to 10 of 10
    Jan 2016
    53
    I'm using the latest Grbl ver 0.9i and I am making 10mm square cuts through 3mm plywood.
    Am I able to execute a gcode command that will allow my cuts to compensate for my laser beam width of 0.5mm so my squares actually come out to 10mm square?
    Thanks for any help...
    Feb 2006
    1792
    Re: Compensating for laser beam width during cut
    I do not have any idea. But can it be not done using radius compensation, if available?
    Jan 2008
    1529
    This is generally something done in CAM. What CAM software are you using?
    Jan 2016
    53
    I'm writing my own gcode actually and sending it to my laser using Universal Gcode Sender. I will look into the radius/tool compensation gcode command.
    Thanks...
    May 2016
    4
    I believe you're looking for G40, G41, and G42. Usually the format is something like "G41 P0.0625" (G41 turns on left compensation [moves your tool to the left of your cutting path by a specified dimension], and P sets the tool "radius"... so half the kerf.) G42 would offset to the right, and G40 would turn off your cutter compensation. As long as you go clockwise around outer perimeters, and counter clockwise around any holes you cut, you can just set a single G41 P(kerf/2) at the beginning of your g-code. (Machines sometimes vary. Make sure to test out your code before cutting anything too pricy)
    If you start using CAM software to write your g-code, usually it factors kerf in for you.
    Jan 2016
    53
    Quote Originally Posted by cwilkes View Post
    Thank you for the detailed answer...I will give that a try with my Grbl ver 0.9i.
    Jan 2016
    53
    Rats...G41 isn't supported in Grbl 0.9i and I thought I had read that it was.
    I get an error: unsupported command at that G41 line:
    G91
    G21
    G41 P0.50
    G01 X0 Y0 F2200
    M03 S76
    G01 X+00 Y+10 F600
    G01 X+10 Y+00 F550
    G01 X+00 Y-10 F600
    G01 X-10 Y+00 F550
    M05 S0
    G01 X12 Y0 F2200
    M30
    Mar 2016
    325
    it may be defined i n different way.
    Usually in milling systems You need first define tool dimmensions (by T and D, H, L commands) and then just choose If You want G41 or G42 (left or right) with no parameters. So try to use it with no parameters and if there won't be error message figure out the way to define tool radius. maybe it,s constant for laser.
    Jan 2016
    53
    I confirmed with the Grbl folks that G40, G41 and G42 have not been implemented. They indicated this would probably not be added in the near future as they have more important Gcode to add to their Grbl.
    Feb 2006
    1792
    Then use a drafting software to obtain the offset profile, and machine along it.
  1. Laser beam runs on the outside of the laser tube!
    By dadde in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 04-18-2015, 03:19 PM
  2. [HELP] The minimum line width of CO2 laser engrave?
    By langtubinhson in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-18-2015, 01:05 AM
  3. Small kerf width laser cutting.
    By RacerAl in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-18-2012, 06:14 PM
  4. Laser beam too big
    By simonsk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2012, 11:45 PM
  5. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
