586,116 active members*
3,457 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > I think my spindle drive is failing
    Mar 2009
    199
    I have a PCNC1100 Serial number 1141 I think. The machine is upgraded to a Series II.
    Last week my spindle speeds were changing on there own at random.
    It was late and needed my parts done so I started using M4 for a while instead of M3 and the symptoms went away and I finished my parts.
    Today the condition returned and the spindle actually stopped running.
    I shut everything down for a while and started it back up. Spindle started but the condition returned.
    When the speed changes I can see it on the drive. I also think I can possibly hear a crackling sound coming from the drive.
    Mach 3 is not aware of the spindle speed changes. Also, I am on mostly original parts on this machine except for the spindle drive upgrade which is original since its purchase.
    I feel like it is the drive but do you know if it can be anything else?
    TIA
    Apr 2012
    84
    Re: I think my spindle drive is failing
    howecnc,
    I'd suggest taking power away from that ASAP! There's a good chance you could blow up the drive which could damage it beyond repair. Send it in to us for a free evaluation. tyler@iesrepairs is my email. I'll PM you my full contact info.
    We fix it all! Give us a call at 855-437-3497.
    Jul 2007
    1602
    I would look for a loose connection.
    bob
    Quote Originally Posted by rowbare View Post
    bob
    Yes, its just a good practice to check the screws that hold all the wires in the terminal blocks once a year. Doesn't hurt to unplug and reconnect the plugs either. All this doesn't take 5 min and can save a lot of headaches.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
  1. MISSING AC SPINDLE DRIVE + 3 AXIS SERVO DRIVE
    By Affaq999 in forum Vertical Mill, Lathe Project Log
    Last Post: 02-20-2015, 03:50 AM
  2. Mach 3 w/Coolant and Spindle Failing
    By webgeek in forum Mach Software (ArtSoft software)
    Last Post: 11-20-2010, 04:06 AM
  3. Spindle inverter failing?
    By rickt395 in forum Fadal
    Last Post: 10-06-2010, 04:05 PM
  4. Profiling program failing
    By Turk88 in forum Haas Lathes
    Last Post: 04-21-2009, 04:37 PM
  5. Please help! Z-axis transistor keeps failing when I turn spindle on
    By jderou in forum Bridgeport / Hardinge Mills
    Last Post: 03-27-2009, 01:09 PM
