586,061 active members*
4,673 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Feb 2004
    8
    Originally posted by buscht
    So my recommendations based upon a grand total of 1/2 hour of messing around.
    1. You can use a scroll saw with fair success. I don't know if this application can be CNC'd with a scroll saw as you need a spiral type bit and I don't know if such a bit is available with a fine enough tooth to cut well.
    2. Other options for cutting this material. a hot wire, similar to used on foam cutters. Maybe someone with one of these machines could test this out.
    I think a water jet or laser would cut this material, but you would be into a commercial application, not a DIY job.
    This is very much outside the box thinking when compared to a CNC router, but I am 99% sure it would work. It might be too time and cost prohibitive to develop however. Especially when you mentioned that you didn't have much time available for experimentation.
    Good luck.
    T
    Thanks for taking the time to screw around with it. Seems like you had similar results. I wonder how a blade with an abrasive coating vs teeth would work. I will monkey around some more this weekend.
  2. #22
    Nov 2018
    Shops or suppliers selling coroplast sheets will solve the problem of size perfectly. https://corrugatedplasticsheet.net/m...plastic-signs/
Page 2 of 2 12
  1. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
  2. cutting Parts from a plate... need some tips
    By Bird_E in forum MetalWork Discussion
    Last Post: 04-10-2005, 04:40 AM
  3. Cutting metal
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 02-20-2005, 06:14 AM
  4. CNC router deflection calcs and cutting loads?
    By Linus in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 04:08 PM
  5. Do you account for climb cutting in G code?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 11-07-2003, 02:21 AM
