STYLECNC® 6090 CNC router
STYLECNC® 6090 CNC router is widely used in Stone,Wood, aluminum, plastic, PVC, PCB, acrylic, crystal, light metal materials, etc. Now the new 6090 CNC router is for sale with best offer.
Wide range of 6090 CNC Router application:
For advertisement engraving and cutting, stone processing, mold manufacturing, wood processing, craft manufacturing, light box cutting, building model cutting, indoor decoration cutting, light equipment mold processing, sign and mark manufacturing,acrylic board processing,etc.
Suitable for Materials:
Stone,Wood, aluminum board, plastic, density board, wave board, PVC, PCB, acrylic, crystal, light marble and other nonmetal materials and light metal material.
Highlights of this New 6090 CNC Router from STYLECNC:
1. Thicker & Stronger Cast iron frame body
much stronger than other Aluimnum frame, make the machine more stable & much better bearing capacity.
2. 1.5KW China best Air or Water cooling spindle
China top quality Changsheng brand, More durable & much lower nose & longer life-time
3. Taiwan HIWIN Linear Guide for Y axis
Top brand Taiwan imported with global service. 10 times longer life- time than round rail or the common brand linear rail. More stable, lower noise, harder to distort.
4. Taiwan TBI ball screw
High precision top brand Taiwan imported TBI Ball Screw
5. Separated control box
It has 2 separated parts which can prevent electrostatic interference
Wires, high soft shielding twisted-pair cable, fire-resistant and with low failure rate, could be bent min 30,000,000 times
6. Top brand electric part: Japanese Omron limit switch
7. Tool calibration sensor(Tool auto-checking instrument)
① More easier tofind the working original home, avoid the manual error, save time.
② Ensure the accuracy.
8. Tool Box (free Accessories)
Including ArtCAM/Type3 Software CD, Water pump, Clamps, Tool holder, Collet, Collet nut, Wrench, Port cable, Power cable, 18 pieces CNC Tool Bits
9. Offline operated DSP control system / Computer controller Economical NCstudio controller
DSP handle controller with USB port, no need to connect into the computer when operate machine, support offline operation, very popular & easily- operated.
STYLECNC is a guaranteed manufacturer for CNC Router, Laser Cutter, Laser Marker, Laser Engraver, Wood Lathe and Plasma Cutter. Official website: https://www.stylecnc.com/
