586,036 active members*
3,938 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA 700M ALERT 128 Memory Disk Format!
Results 1 to 10 of 10
    May 2016
    4
    Hi Everyone,
    We have only one OKUMA 700M in our plant. It has been working for 5 or more years.
    One year ago memory of the machine became full and an operator opened control block and replaced the battery spontaneously in the memory board.
    After that the machine stopped to run properly. When power is on, it is checking (I think so) itself and gives SBP monitor message 80 (128 - Memory Disk Format), even not booting.
    I wanted to debug, unfortunately in install mode it shows the same error after install command.
    I have released that this message is appearing whether memory board installed or not in control block.
    We have tested memory board somehow, and its' hardware part is working properly.
    So could anyone give any advise?
    What i have to do?
    Thank you for reading.
    Thank you for advise.
    Regards
    Apr 2006
    822
    Re: OKUMA 700M ALERT 128 Memory Disk Format!
    There is a specific battery replacement procedure, normally only used by Okuma service personnel.
    By removing the battery you have lost all your parameters.
    A full system reinstall is now required.
    You will need to use your install disks.
    Not sure if you will now need the Battery replacement disk or not.
    Guess it is time to give it a go on the reinstall method as specified in your manual.
    May 2016
    4
    Dear Broby,
    Thank u for ur quick reply and advise.
    Now I am sitting on reading all required manuals.
    I will post results soon.
    Regards!
    Apr 2006
    822
    Good luck.
    The process is not difficult, but you do need to follow the instructions in the manual.
    Pretty much a case of Start up in Install mode.
    Feed in disk 1 through to disk n...
    Restart.
    Make sure limit parameters are set as per the data sheet in the electrical cabinet (usually).
    Obviously, all tool data will be gone.
    May 2016
    4
    Thanks a lot.
    In section 4 of the maintenance manual there is procedure for installing software.
    I have done steps, following instructions:
    1. I turn on NC and switched ON in INSTALL MODE.
    2. Then pressed RESET button.
    3. In the screen appeared [MAIN MANU] with three items: 1.Install 2. Diagnosis, 3. Extend
    4. I entered number 1
    Unfortunately, it again showed the same error: 128 Memory disk format.
    Maybe I missed something. In control block, red led in MB1 board still lights up.
    What I did wrong?
    Tomorrow I will read again and try.
    Regards
    Feb 2009
    6028
    Did he hook up the battery backwards? That will fry the memory board.
    Sent from my A3-A20FHD using Tapatalk
    May 2016
    4
    Hello Broby,
    I did procedure following instructions in manual:
    a) turn on the power supply
    b) set the Install Mode switch to ON (I)
    c) Insert the INSTALL floppy disk (1/n) into the floppy disk drive
    *-in my case, there are 9 floppy disks.
    1 - install disk
    d) Press the System Reset button
    * After pushing this button system reseted. System (or boot) is loading from floppy disk.
    Then appeared following screen in displey.
    PiXS.ru / ????????? ???????? ??? ?????? / ???? ??????? / ????? ???????
    In manual it is recommended choose 0 to install package (disks from 2 to 9).
    Whether I chosed 0 or 1 it is displaced error screen.
    I have no information whether a worker hooked up the battery backwards or not. When we tested it, we could not find any fault in memory board. By the way, my suspicion falls on the memory board.
    And in manual I met instructions, procedures with floppy disk "D" several times (for example, The floppy disk "D" method should be used when the flash memory has failed for some reason, or when the OS has not been installed. - Section 4, page 23). But in disk package there was only 10 disks: Package floppies (9 disks) and Backup floppy (1 disk).
    What I should do next?
    Thanks in advance.
    Regards.
    Apr 2006
    822
    Sorry, do not know. Think it might be time to call your nearest Okuma engineer.
    Aug 2012
    164
    You need to initialize the memory; it requires a specific utility disk that your dealer will have. If that doesn't work, then your memory board is bad (highly unlikely since it sounds like everything was fine until you changed the battery.
    Apr 2011
    112
    hello how did you solve the problem i have a similar error on a u100m olso a 252 ram error
  1. Okuma OSP 700M/7000M RS-232 parameters
    By sld4121 in forum Uncategorised MetalWorking Machines
    Last Post: 05-01-2013, 06:33 PM
  2. okuma osp 700m
    By bennyboy78 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-14-2011, 02:07 PM
  3. Charmilles Robofil 310 disk format error
    By ecduplex in forum EDM Discussion General Topics
    Last Post: 12-06-2010, 09:50 AM
  4. Okuma Osp-700m Dnc Parameters !!!
    By miguisu in forum DNC Problems and Solutions
    Last Post: 05-16-2007, 04:13 PM
