586,076 active members*
3,893 visitors online*
    Nov 2005
    111
    Mach3 and Drivertest.exe
    Hello,
    I want to drive my lathe with Mach3 and external controllers, but with no sucsess. I buy a computer and a card with two printerports and install Mach3. When I run the Drivertest.exe the message on the screen is: "System excellent", up to 100kHz. Does this mean that the printerports are correct working? What will be a good working frequency with Mach3 and Printerports?
    Many thanks for every answer
    Hans
    Re: Mach3 and Drivertest.exe
    The "System Excellent" is rather meaningless.
    You want to see a steady pulse rate, and a flat line with no spikes.
    You want to use the lowest kernel speed that you need that will provide your maximum velocity. Higher kernel speeds can make the PC unstable.
  1. To mach3 or not mach3, opinions requested
    By KenCameron in forum HURCO
    Last Post: 10-07-2014, 10:05 PM
  2. Drivertest.exe pulsing too fast issue
    By jevs in forum Mach Software (ArtSoft software)
    Last Post: 02-12-2013, 10:32 PM
  3. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  4. mach3 drivertest result
    By chepot in forum Mach Mill
    Last Post: 04-11-2009, 03:25 PM
  5. help DriverTest
    By kujau in forum Mach Software (ArtSoft software)
    Last Post: 03-10-2007, 05:57 PM
