Ok so I found a bug, for those who use english inch as in the quote and use fractions, well we have a problem with the Save as user operation, the issue is the name of the operation that goes as the file name takes on the invalid characters " /
The temporary solution is this: Simply save your operation, it still shows up in that session as its being cached. But you must go and edit the user operations and change the name! of the operation without the invalid system characters
This will im sure get fixed, I reported but wanted to let you guys know what was the cause of the lack of saving.
You can see in my image that the name will not work! You get no error nothing, the file simply never gets saved, once you change the valid file name and hit apply, you can go to the folder and actually see your saved user operation!
Example what is shown in picture:
C:\ProgramData\Sprut Technology\SprutCAM\Version 10\Operations\1/2" DRILL01.stox
simple change to
C:\ProgramData\Sprut Technology\SprutCAM\Version 10\Operations\0.5 in DRILL 01.stox
fixes the issue
(FYI you can change the location of your saved files here as well)
