586,106 active members*
3,134 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > How to alter soft overtravel limits for second head on star sr-32j
    Feb 2016
    5
    Hi all ive got a graph turning tool to use on tool 21 on my star sr-32j but i need to alter the soft over travel limits but dont no which parameters it is i need to change any help would be greatly appreciated
    TIA
    Luke
    Sep 2011
    261
    Re: How to alter soft overtravel limits for second head on star sr-32j
    I am not familiar specifically with your Star machine, but parameter 1320 is the + soft overtravel limit and 1321 is the - soft overtravel limit on nearly all fanuc machines
    The parameter is in millimeters regardless of your input unit.
    If you change it, I recommend that you carefully find where the hard limit is, as on some machines it is very close to the soft limit. TO find the hard limit, you can change the value to a larger one, then very slowly hand wheel the axis towards overtravel. While you do this, go to your servo load monitor screen (push: Position -> extend -> Moni), and stop when you see your servo load increase steadily. That is an indicator that you have reached the hard limit. Once you know your actual hard limit, you can convert that position to milimeters, add a .01" (or more) safety buffer and enter that value into your overtravel parameter.
    CNC Product Manager / Training Consultant
    Feb 2016
    5
    Thanks for the reply ill give that a shot when im at work tomorrow thanks ill let you no how i get on
  1. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  2. OT003X Overtravel (soft 2)
    By GM81 in forum DNC Problems and Solutions
    Last Post: 05-09-2008, 06:18 PM
  3. SOFT OVERTRAVEL
    By metx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2007, 06:06 AM
  4. takisawa tc-20 21-t control soft overtravel
    By CVMW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-11-2007, 01:12 AM
  5. Replies: 1
    Last Post: 08-13-2007, 02:56 PM
